Settle a bet: Mach speeds
Old June 7th 04, 04:42 AM
Mary Shafer
On Sat, 15 May 2004 21:25:59 -0500, "tscottme"
I ask because I've heard NASA folks mentioning that the Shuttle, at some
point in it's descent, is going Mach 25. I claim that means the vehicle
is going 25 times faster than Mach at that particular pressure and temp
where the Shuttle is, while someone else claims NASA means 25 times the
sea level value of Mach, even though the Shuttle is in the very upper
atmosphere at the time.
[I'm sorry to be so late in replying, but life got weird and it took
me a little while to get back to this. MFS]
It's a definition thing. The Orbiter goes Mach 25, by definition,
until the dynamic pressure gets high enough to be sensed, which is at
(surprise!) Mach 25. If you use the real dynamic pressure, which is
zero, the Mach number goes to infinity, so we set it to Mach 25 by
definition to avoid that.
It isn't sea level Mach number for that airspeed. No one uses
"equivalent Mach number". That's because the aerodynamics and
aerothermodynamics are functions of Mach number, so it has to be
local.
This means you're right and someone else is wrong.
Perhaps that someone else is confused by equivalent airspeed, usually
presented by PAO as miles per hour. That is the sea-level airspeed
that the airplane would have to fly at to have the same Mach number at
sea level that it has at altitude.
I don't have my calculator or my standard atmosphere here, so the
numbers I'm about to give you will be only approximate. Flying Mach 3
at 80,000 ft is an indicated airspeed of about 300 knots (300 KIAS).
At sea level, the equivalent airspeed would be about 3,000 fps, which
you'll have to convert to knots (this will be KEAS).
I know to discount what reporters say, but I'm referring to engineers
and their official spokesmen.
You can check this in "Space Shuttle Hypersonic Aerodynamic and
Aerothermodynamic Flight Research and the Comparison to Ground Test
Results", Kenneth W. Iliff and Mary F. Shafer, NASA-TM-4499, June,
1993. If you go to http://www.dfrc.nasa.gov/DTRS/1993/Bib/H-1894.html
there's a link to a pdf version.
One of the early references explains the air data system, including
this Mach number definition.
Mary
Mary Shafer Retired aerospace research engineer
Old June 7th 04, 10:16 AM
Cub Driver
On Sun, 06 Jun 2004 20:42:51 -0700, Mary Shafer
I make 3,000 fps to be 2.758 knots....
all the best -- Dan Ford
email: (put Cubdriver in subject line)
The Warbird's Forum
www.warbirdforum.com
The Piper Cub Forum www.pipercubforum.com
Old June 8th 04, 08:17 AM
John Keeney
"Cub Driver" wrote in message
Did I miss something, like a really strange joke or
that you're calculating some (correction?) factor at
3000 fps and want the answer in knots?
Did you really determine 3000 feet per second to
be less than 3 knots? Knots as in nautical miles per hour?
Or perhaps it was a type and you meant 2758 knots?
2578 knots would still be way off, but it would at least
be of the right magnitude;
3000 fps = 2045.4545... mph ~= 1777 1/2 knots.
Got to be the correction factor...
Old June 8th 04, 10:16 AM
Cub Driver
Perhaps my calculator left off some zeros.
On Tue, 8 Jun 2004 03:17:26 -0400, "John Keeney"
The Warbird's Forum
max altitude and Mach 1 Now With Charts John R Weiss Military Aviation 6 May 15th 04 05:49 PM
F-22 Comparison robert arndt Military Aviation 39 December 4th 03 04:25 PM
WWII warplanes vs combat sim realism [email protected] Military Aviation 37 November 27th 03 05:24 AM
The Wright Stuff and The Wright Experience John Carrier Military Aviation 54 October 12th 03 04:59 AM
Me-262, NOT Bell X-1 Broke SB First robert arndt Military Aviation 140 October 10th 03 08:02 PM
