On Monday, January 25, 2016 at 11:27:41 PM UTC-5, wrote:
if I understand correctly, the warm temp reducer results in less orange peel, correct? Is that because up takes longer to evaporate, giving the paint more time to "spread out". I was using the medium temp, but the high temp stuff may be worth a try. Thanks! That is my experience as I tried to describe in an earlier portion of the thread. That said, much of the orange peel is a result of less than perfect gun adjustment and technique. Finish paint wants a smaller tip than filler and more attention to adjustments. Big droplets coming out of the gun not fully atomized are not going to be as flat as finer mist. It takes a long time to become a good painter and most of us get to be good sanders first. For sand out look at 3m Trizact sanding discs used on an orbital sander. 1500 grit, followed by 3000 grit will make it easier to do a good job. Contact me privately if you want more detail. UH |
Urethane Paint | Jonathan St. Cloud | Soaring | 44 | November 20th 15 10:48 AM |
urethane 2K paint | [email protected] | Soaring | 1 | February 4th 14 11:30 PM |
Reducing canopy glare caused by instrument face reflections. | [email protected] | Soaring | 1 | November 11th 13 09:22 PM |
Reducing Fuel use and Increasing your car speed with FFI MPG-CAPS | sexy girl | Piloting | 0 | February 23rd 08 05:47 AM |
Reducing the Accident Rate | Snowbird | Piloting | 92 | July 22nd 04 01:31 PM |
