"Larry Smith" wrote in message ...
"Lpmcatee356" wrote in message ... where can I find construction details - howto files? Try downloading the Quicke construction manual. It's not much more than a seat with wings. www.finleynet.com I used an ergonomically designed race-car seat as a mold and laid one up using Rutan cloth and epoxy, then reinforced it with foam and a few more layers of glass. The best way to learn about glass layups and molds is reading Rutan's treatise on moldless foam construction and watching Mike Arnold's AR-5 videotapes. Btw, the strength is not in the epoxy but in the fiberglas. Or S-glass, or carbon fiber. However the resin matrix permits the fibers to realize their strength. At its website Cessna explains why it uses exclusively aluminum construction. Cessna says there are too many unknowns regarding glass and that aluminum is better. Well, aluminum IS better in some respects, but glass is also better in many respects too. Fiberglas is easy to repair, it lends itself nicely to compound curves, it does not corrode or fatigue like aluminum, it is capable of absorbing more shock than aluminum, and its strength-to-weight ratio cannot be beat. Plus, when is the last time you saw a laminar flow wing made of aluminum? You have to be very careful not to get your glass layup overweight. You have to be very careful not to let your glass ship get hot in the sun. You have to be very careful not to let UV rays eat the resin. But then, composite construction must be viable or you wouldn't see so many Lancairs, Cirruses, White Lightnings, Pulsars, and Eezies boring holes through the sky. Composite construction is labor-intensive, and that's part of the reason why Boeing and M-D haven't migrated to it completely. Give them time. Boeing are rapidly moving over to composite manufacturing if you look at the press releases on the new Boeing 7E7 dreamliner project the use of composite parts in the aircraft has risen dramatically and now it is not just non-structural items composites are now being used to manufacture major structural items such as tailplanes fins bulkheads etc. The Airbus A380 is also making extensive use of composites to minimise weight. I believe that Boeing and Airbus both realise that the time of composites has come they are just being cautious and implementing a bit more with each new model. |
Registration of Aircraft in Oklahoma City | Larry Smith | Home Built | 2 | November 10th 03 05:07 PM |
Laser-powered Aircraft | Big John | Home Built | 10 | October 13th 03 05:30 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 03:07 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
