How about something like this on top of the fuselage and another on the bottom? If mounted from the inside through a hole it would be less than 20mm tall and I'm guessing a streamlined bubble to cover it wouldn't add any significant drag.
https://www.superbrightleds.com/more...Specifications This appears to be the same as used on emergency vehicles and with a draw of over an amp at 12v, it sure seems like it should be bright. I'm sure a much slower flash rate would reduce the current draw. I've seen a bicycle headlight strobe while looking into the rising sun from more than 4 miles. I was sure it was a police car flashing headlight with someone in front of him covering one of the lights. But when I got closer it was a bike! 5Z On Wednesday, January 27, 2016 at 12:11:48 PM UTC-8, son_of_flubber wrote: LED lights for the shade and mirror for sunlight would be complementary. A forward facing LED strobe is a big payback even though it works on only one axis. |
Aircraft Markings | Stretch | Aviation Photos | 4 | January 13th 08 12:39 PM |
HC-1 SH-3 1972 markings ? | Mike Weeks | Naval Aviation | 0 | May 17th 07 04:12 AM |
B-29 tail markings | Peter Twydell | Military Aviation | 11 | September 10th 04 10:28 AM |
High Visibility markings research? | Craig Reynolds | Soaring | 2 | June 3rd 04 11:25 PM |
P51 maintenance markings | Serge Seguret | Restoration | 1 | May 26th 04 02:50 PM |
