At 05:03 28 January 2016, Ramy wrote:
Not intending to offend anyone, just to solicit thought, not rote acceptance. Show me the beef. (by way of full disclosure, I not not eat beef). Assuming no one is considering wrapping their whole glider in orange glow, = only the wing tips, part of the rudder and maybe part of the nose. How coul= d this possibly act as camouflage?? By reducing the visible wing span by le= ss than 5%? This sounds like a myth. Worst case scenario it will have no im= pact, base case scenario the small orange surface will catch your attention= and save your life. So instead of debating it to death, best is to just pu= rchase a stripe of orange vinyl (less than $50) and stick it to your wing t= ip/winglets/rudder. It will make your glider look prettier, more unique, an= d maybe even safer. And if you dont like it - remove it... Ramy Camouflage works by breaking up the outline of a familiar object so that the eye/brain does not recognise it, or alternatively confuses the eye/brain. British soldiers in your war of independence wore red coats, because red made it difficult for the enemy to count the number of soldiers, to camouflage the size of their force . Ships in WW1 were painted in garish zig-zag patterns which broke up the outline so they were less likely to be recognised as ships and made range estimation difficult. It is not as simple as it seems. Sticking it to your rudder is a bad idea, as has been pointed out earlier. Altering the mass balance of a control surface, even by a small amount, without comprehensive testing, is unlikely to end well. |
I was at a Nationals at Caesar Creek, OH one summer and was running in the mornings. Like everyone else, I knew bright orange was highly visible (duh) so that's the color of the shirt I wore. One morning at the pilots meeting, a competitor commented that he hadn't seen me alongside the road that morning until he was almost on top of me. "Wear white," he suggested, "it's more visible against the trees and vegetation in this area." So I did, and he confirmed my greater visibility the next day.
The trouble with conventional wisdom is that so many people assume it's true because it seems logical--but without ever checking. There's another category of experts who continue on with, in essence, "don't confuse me with the facts; I know what I know," evidence from experimental studies to the contrary. For the record, the Big Sky theory works very well. 99%+ (probably high 9s) of aircraft in flight don't collide. But it's not perfect. That's why we keep our eyes open, look for ways to make our gliders more visible in the environments in which we usually fly, and rely increasingly on electronic anti-collision technology to improve the odds still further. The studies on glider conspicuity I've seen were all performed in Europe. It would be interesting to see the results of a similar study in an area like Nephi, or Hobbs, or Uvalde, or Minden on a typical summer soaring day. I've flown at the latter three sites but not at Nephi. Chip Bearden |
I would like to see the experiment method described in detail. While I have not conducted any tests on high visibility colors, I can tell you they work on my eyes for roadside workers, construction crews, hunters, and they single glider I have seen with the day-glo orange, all the above were highly visible. I also know from merging and formation flying the aircraft with red really stood out.
As a former engineer I will gladly accept well designed test results. But if you do not publish the experiment method, in detail, then the conclusion is suspect as it has not undergone peer review. Having said that, I am depending on eyes, Flarm and LED strobe in my bird. The studies on glider conspicuity I've seen were all performed in Europe. It would be interesting to see the results of a similar study in an area like Nephi, or Hobbs, or Uvalde, or Minden on a typical summer soaring day. I've flown at the latter three sites but not at Nephi. |
On Friday, January 29, 2016 at 2:31:47 PM UTC-5, Jonathan St. Cloud wrote:
I would like to see the experiment method described in detail. Below are some snipped relevant paragraphs from the most recent conspicuity study I could find online. I recall reading several others, including one that was referenced in this thread recently, but the conclusions were the same, IIRC. Speaking as a former engineer, the methodology designed and employed by Dr. Head and his associates for the important "head-on-converging" scenario seems reasonable. It's likely a worst case "no relative movement" converging tracks situation. I agree that red/orange tips and tail are pretty visible on the grid, across a thermal, looking up at the sky, or even looking down against a contrasting background. But the scenarios most of us worry about are those where two aircraft are converging at similar altitudes with little relative motion for the eye to pick up. There are variations of this, of course, involving another aircraft approaching from the side (as when several gliders converge on an already established thermal from different directions at the same level--one where I've almost been clobbered a few times) or a power plane overtaking from directly behind (another personal near miss). But the one that seems to get the most attention is head on under a cloud street (a la the Uvalde incident some years ago). The full Bicester report includes details on other trials involving simulated thermaling, mirror film, and black underside paint. I'm sure there are other ways to run these tests but this team seems to have made a competent, good-faith effort to experimentally determine the effectiveness of different types of markings/colors on glider visibility. Unlike at least one other test I've heard about, this group stopped short of saying that the Day-Glo markings made a glider less likely to be visible. So I guess there's no harm pimping your ride if it makes you feel better. But keep those eyes open. From "See and avoid?" Dr Tony Head, from the College of Aeronautics at Cranfield University, reports on the outcome of recent conspicuity research conducted at Bicester (from "Sailplane & Gliding", Aug-Sep 2003) http://uvs-international.org/phocado...sep%202003.pdf Trial Four: Air Cadets' DayGloİ pattern during constant-bearing converging paths The randomisation and the direction of runs was as for Trial One and Figure 1 (p29). Weather was excellent with scattered cloud and visibility in excess of 25km. [excerpt follows from p29 describing Trial 1 methodology] Crews flew toward a central point at 2,000ft AGL and 70kts ground speed (as indicated by GPS). Each pair of crew was given a set of headings to fly for both outward and inward tracks. When crews sighted the other MG, they called "Mark" on the radio and noted their distance from the central point as indicated by GPS. Once both MG had been sighted, crews reversed track and began the next run. An example of the randomisation and the direction of runs is shown in Figure 1, below. The distance between the aircraft was calculated by simple trigonometry, the distances of both MG from the central point being noted and recorded at the time of visual contact. [end of excerpt] Results: There were no significant differences in detection distances between the clean (2.67nm) or DayGloİ MG (2.82nm). The mean detection distance for all of the runs was 2.75nm, with ranges from 0.88 to 5.3nm. The weather for these trials was ideal, with sunlight and scattered cloud. The overall mean detection distance of 2.7Snm was considerably better than in trial 1 (1.69nm) reported here, when the weather was less than ideal. In the previous trials carried out in 2000, where similar DayGloİ patches were applied to the MG, the overall mean detection distance was a comparable 2.54nm. As the crews were different for the 2000 and 2002 trials, there can be no meaningful statistical comparison. However, the mean detection distance, in good conditions, with hyper-vigilant crews, for all MG with or without DayGloİ, is only 2.64nm. The crews, who were initially very enthusiastic about the larger DayGloİ patches, confirmed that they did not appear to aid conspicuity. The two studies, in 2000 and 2002, that examined conspicuity of MG during constant-bearing convergence, failed to demonstrate a significant increase in detection distance with the use of the DayGloİ patches. There appeared to be no measurable negative effect upon conspicuity either. Any detection was consistently reported to be due to the silhauette of the MG or to a glint, and not to the DayGloİ. |
Two personal experiences:
In one of my clubs, an ASK-13 was painted completely in bright orange. The only situation where this was really visible was in bright sunlight when flying slightly higher. In all other situations it just looked gray/black, just like any other sailplane. During one alpine flight, with a green/brown backdrop (no snow) and with the sun in the back, I was surprised at seeing a series of white dots coming in my direction. It was a glider with a series of hi-vis stripes, approximately 50 cm wide, taped chordwise every meter or so on the leading edge. The white was decidedly more visible than the stripes... With a snowy backdrop, bright orange markings are a welcome plus, but I prefer large markings at the wingtips rather than numerous small strips all over the sailplane. I used to fly in a Janus with two classic white strobe lights, one under the nose in front of the nosewheel, the other on the back just behind the canopy. No improvement in visibility in full sunlight, but very visible when flying in the shadow of the clouds (cloudstreet, convergence). Not sure the new "LED" strobes would be as efficient, but certainly worth a try. |
On Saturday, January 30, 2016 at 5:45:06 PM UTC-5, Don Johnstone wrote:
I think it is a common finding in this thread that almost nothing increases the visibility of a glider approaching head on, in fact some markings may reduce visibility. The frontal area of a modern glider is so small so with no relative lateral or vertical movement they are very hard to spot. The exception to that might be a forward facing narrow beam white LED strobe. Say a 15 degree cone. |
Aircraft Markings | Stretch | Aviation Photos | 4 | January 13th 08 12:39 PM |
HC-1 SH-3 1972 markings ? | Mike Weeks | Naval Aviation | 0 | May 17th 07 04:12 AM |
B-29 tail markings | Peter Twydell | Military Aviation | 11 | September 10th 04 10:28 AM |
High Visibility markings research? | Craig Reynolds | Soaring | 2 | June 3rd 04 11:25 PM |
P51 maintenance markings | Serge Seguret | Restoration | 1 | May 26th 04 02:50 PM |
