Standardization in Slack Rope Recovery?
  #11
Old February 2nd 16, 01:25 AM posted to rec.aviation.soaring
Bob Pasker
Default Standardization in Slack Rope Recovery?
there are two kinds of CFIs: one kind evaluates your overall skill and safety, and the other kind thinks they can make you into a new pilot in an hour's flight. the first kind are not a problem. the second kind need to be appeased.
On Monday, February 1, 2016 at 11:43:07 AM UTC-5, son_of_flubber wrote:
On Monday, February 1, 2016 at 10:08:52 AM UTC-5, Bob Pasker wrote:
good catch
I should have said that I was "less interested in performing the maneuver the way I was taught and the way I did it on my checkride, than I am in pleasing the CFI"
I question your deference to the CFI.
I'd be much more interested in practicing the maneuver the way I always practiced the maneuver (yaw slightly away from the slack). Removing slack is something that I do without thinking about it and if I had the opportunity to practice with 'deliberate slack rope', I'd profit by reinforcing my 'muscle memory'.
Learning the CFI's unfamiliar way of removing slack is counter-productive, especially if it means risking the possibility of a second loop from doing something improperly. What is the point?
So it seems best to resolve on the ground what techniques I'm going to use in the air. If the CFI wants me to do it differently, then he'd have to convince me that the way I was taught to do something was dangerous. If he were inflexible and insisted on doing things his way, I might opt out of getting in the glider with him. If we can't get along on the ground, then I should not fly with him.
I've flown with many CFIs. I'm grateful to all of them. Only one was rigid, inflexible, and unable to carry on a conversation that deviated from his shop worn script. In retrospect, I should have opted out of flying with him.
Rope Break Walt Connelly Soaring 4 April 12th 11 09:04 PM
tow rope tazman Soaring 9 August 25th 10 02:30 AM
Slack line with water Ron Ogden Soaring 10 May 5th 09 05:55 PM
OK you slack bastards Glenn[_2_] Aviation Photos 5 July 6th 08 02:49 PM
11 on a Rope Peter Seddon Rotorcraft 0 May 27th 04 11:33 AM
