![]() As the N4DM is certified, it had to be demonstrated that it will exit a spin after 3 turn at most. Loosing 1800 m in any certified glider while trying to stop the spin is hilarious. Maybe not if you in it. But I do see your point, was a spiral mistaken for a spin? Cheers Paul This corresponds to something like 12-15 turns. Something has gone wrong very seriously. Bert Ventus cM TW |
The very long wing open class gliders have a bad record on spin recovery.
They will generally transition to a spiral dive quite early in a spin, but will accelerate very rapidly on the exit. If they do get into a stable spin, the momentum in the wings is a problem. If you have water in the wings, or fuel, then you are a test pilot. Certification is done dry. There are at least five Nimbus 4D accidents I am aware of where recovery was past Vne and the glider broke up on recovery. Ash25 - same story. Bruce On 2016-02-02 08:12, Paul B wrote: As the N4DM is certified, it had to be demonstrated that it will exit a spin after 3 turn at most. Loosing 1800 m in any certified glider while trying to stop the spin is hilarious. Maybe not if you in it. But I do see your point, was a spiral mistaken for a spin? Cheers Paul This corresponds to something like 12-15 turns. Something has gone wrong very seriously. Bert Ventus cM TW -- Bruce Greeff T59D #1771 |
On Tuesday, February 2, 2016 at 3:41:35 AM UTC-5, BruceGreeff wrote:
The very long wing open class gliders have a bad record on spin recovery. They will generally transition to a spiral dive quite early in a spin, but will accelerate very rapidly on the exit. If they do get into a stable spin, the momentum in the wings is a problem. If you have water in the wings, or fuel, then you are a test pilot. Certification is done dry. There are at least five Nimbus 4D accidents I am aware of where recovery was past Vne and the glider broke up on recovery. Ash25 - same story. Bruce Bruce Greeff T59D #1771 "Certification is done dry..." No. Current CS-22 Amendment 1: "CS 22.221 General (a) Compliance with the following requirements must be shown in all configurations and, for a powered sailplane, with the engine idling. For sailplanes equipped to carry water ballast, the demonstrations of sub-paragraphs (b) to (g) must also be made for the most critical water ballast asymmetry that might occur due to any single malfunction or due to lateral accelerations during a spin." Then, in spin testing (later in CS22 AL1): "AMC 22.221(b) Spinning General It will normally be sufficient to conduct a number of spins of about two turns in each of the conditions of CS 22.221(b) and subsequently to conduct spins of five turns in the most adverse cases." You may recall the ETA spin test with one wing full/one empty led to a crash. Both CS-22 AL1 and the ETA test are available by mr. google. |
Le mardi 2 février 2016 13:41:43 UTC+1, Dan Daly a écrit*:
You may recall the ETA spin test with one wing full/one empty led to a crash. Both CS-22 AL1 and the ETA test are available by mr. google. No. The Eta crashed when trying to recover from a spiral dive (dry). The load on the rudder simply snapped the tail boom. The ASH25 did crash during flight testing when spinning with water in only one wing. The centrifugal force of the water made the wing skin pop, and Martin Heide had to parachute down. He had been suspicious about this outcome beforehand and had tried to talk authorities into dropping this part of the test, but to no avail. So he did the test starting at 10'000 ft. |
On Tuesday, February 2, 2016 at 8:48:43 AM UTC-5, Tango Whisky wrote:
Le mardi 2 février 2016 13:41:43 UTC+1, Dan Daly a écrit*: You may recall the ETA spin test with one wing full/one empty led to a crash. Both CS-22 AL1 and the ETA test are available by mr. google. No. The Eta crashed when trying to recover from a spiral dive (dry). The load on the rudder simply snapped the tail boom. The ASH25 did crash during flight testing when spinning with water in only one wing. The centrifugal force of the water made the wing skin pop, and Martin Heide had to parachute down. He had been suspicious about this outcome beforehand and had tried to talk authorities into dropping this part of the test, but to no avail. So he did the test starting at 10'000 ft. ****** According to the Oct 2009 BFU Investigative report 3x221-0/05, the test was a spinning trial with asymmetric fuel (not water as I said - you are correct on that) - page 1 (History of the flight). According to the conclusions, the spin changed to a spiral dive and the use of rudder for recovery broke the tail (page 5). I guess we are both right, and both wrong in some parts! The asymmetric condition was not noted in conclusions, so probably not critical in comparison to the engineering conclusions. I didn't say anything about ASH25 but it sounds interesting... I did a brief search but couldn't find it online. When did it happen? Thank you for the correction. |
Le mardi 2 février 2016 15:59:41 UTC+1, Dan Daly a écrit*:
On Tuesday, February 2, 2016 at 8:48:43 AM UTC-5, Tango Whisky wrote: Le mardi 2 février 2016 13:41:43 UTC+1, Dan Daly a écrit*: You may recall the ETA spin test with one wing full/one empty led to a crash. Both CS-22 AL1 and the ETA test are available by mr. google. No. The Eta crashed when trying to recover from a spiral dive (dry). The load on the rudder simply snapped the tail boom. The ASH25 did crash during flight testing when spinning with water in only one wing. The centrifugal force of the water made the wing skin pop, and Martin Heide had to parachute down. He had been suspicious about this outcome beforehand and had tried to talk authorities into dropping this part of the test, but to no avail. So he did the test starting at 10'000 ft. ****** According to the Oct 2009 BFU Investigative report 3x221-0/05, the test was a spinning trial with asymmetric fuel (not water as I said - you are correct on that) - page 1 (History of the flight). According to the conclusions, the spin changed to a spiral dive and the use of rudder for recovery broke the tail (page 5). I guess we are both right, and both wrong in some parts! The asymmetric condition was not noted in conclusions, so probably not critical in comparison to the engineering conclusions. I didn't say anything about ASH25 but it sounds interesting... I did a brief search but couldn't find it online. When did it happen? Thank you for the correction. I think that the ASH25 happened in 1985 or 1986. Martin Heide told me about it a week or two later. |
On Tue, 2 Feb 2016 07:12:13 -0800 (PST), Tango Whisky
wrote: I think that the ASH25 happened in 1985 or 1986. Martin Heide told me about it a week or two later. .... actually it was the ASW-22 prototype. |
Namibia - Bitterwasser | rhwoody | Soaring | 4 | March 2nd 11 09:33 PM |
Ventus 2cxM Solo 2625 01 EGT Installation | Chris Woolley | Soaring | 2 | April 4th 08 04:09 AM |
Gliding in Namibia | Ian Johnston | Soaring | 13 | April 29th 06 07:01 AM |
[PICTURES] NAMIBIA | Frederic FUCHS | Soaring | 6 | January 13th 06 02:58 PM |
Flying In namibia | tom | Piloting | 1 | March 22nd 05 07:07 PM |
