On Tuesday, February 2, 2016 at 3:47:08 PM UTC+3, James Thomson wrote:
At 11:02 02 February 2016, Bruce Hoult wrote: "Rigging" is a set of devices for adjusting positions, angles, tensions etc= of aerodynamic surfaces -- or as a verb the use of such adjustments. Origi= nally from sailing ships but later applied to aircraft (which were initiall= y made in very similar ways. The "rigging angle", for example, refers to th= e angle between the chord of the wing and the fuselage. What we refer to as "rigging" of gliders is merely the use of precision qui= ck-release mechanisms that are expressly designed to not alter the settings= ! Rigging could be referring to control deflections. These are not affected by the operation pilots call "rigging" but they can, and do, change due to wear and to the replacement of parts in the control linkages. They are adjustable by maintenance personnel. If the deflections are wrong the glider will not handle as designed and expected. My point, precisely. |
Namibia - Bitterwasser | rhwoody | Soaring | 4 | March 2nd 11 09:33 PM |
Ventus 2cxM Solo 2625 01 EGT Installation | Chris Woolley | Soaring | 2 | April 4th 08 04:09 AM |
Gliding in Namibia | Ian Johnston | Soaring | 13 | April 29th 06 07:01 AM |
[PICTURES] NAMIBIA | Frederic FUCHS | Soaring | 6 | January 13th 06 02:58 PM |
Flying In namibia | tom | Piloting | 1 | March 22nd 05 07:07 PM |
