Factory installed com antenna in the fin.
Old February 2nd 16, 08:04 PM posted to rec.aviation.soaring
Heinz Gehlhaar
Default Factory installed com antenna in the fin.
On Tuesday, February 2, 2016 at 6:43:02 AM UTC-8, shkdriver wrote:
Hey Group,
I've got a 1975 Std, Cirrus new to me. I am replacing the com radio and in the process I deleted a poorly done splice in the coax cable with a rg-58 solder end.
After the bnc end was installed, I measured the resistance between the center and shield leads, I measured 0.9 ohms,
Snip snip
Not too surprising. Look up Gamma matched antenna; the antenna is a dc short circuit.
Heinz
Old February 3rd 16, 11:21 PM posted to rec.aviation.soaring
Most 'loaded' antennas will show little to no resistance. I just checked one and got .2 to .9 ohms. Recommend you get the BNC properly attached, then hook up your radio and give it a range check
JJ
Scenes From The Factory Floor, Concluded - Wirraway factory Australia 1940 b.jpg (1/1) Mitchell Holman[_8_] Aviation Photos 0 January 29th 15 01:22 PM
Scenes From The Factory Floor, Concluded - Wirraway factory Australia 1940 a.jpg (1/1) Mitchell Holman[_8_] Aviation Photos 0 January 29th 15 01:22 PM
Scenes From The Factory Floor 15 - Spirit St Louis Ryan Factory.jpg (1/1) Mitchell Holman[_8_] Aviation Photos 5 January 29th 15 04:50 AM
Comm antenna distance from pilot? Becker flex antenna? [email protected] Soaring 3 January 16th 13 10:16 AM
406 ELT Aircraft Installed - Anyone find one? - Internal carbonfuselage antenna WaltWX[_2_] Soaring 5 March 17th 12 05:44 AM
