Charles Talleyrand wrote:
"Eunometic" wrote in message om... My feeling is that knowledge of materials for engine development was what kept engine weight up and kept down the performance of most of these aircraft. For instance an engine of the quality of the cyclone seen on Charles Lindbergs Spirit of St Louise would have immeasurably improved the performance of these aircraft especially if fitted with NACA style cowlings. It most certainly was easily buidable by the fabrication techniwques of the day. Prior to that engines were bulky liquid cooled models or clumsy rotaries. Suppose someone gives them a construction manual and a prototype of a radial engine (probably without the turbocharger) for any common radial engine of the 1940s. Can they get the correct alloys and build to the needed tolerances? No, and just as importantly, they probably couldn't produce fuel of sufficiently high octane to allow it to produce the higher power it's capable of, even if they could build the engine, and chances are the oil would be inadequate as well (petroleum engineers with a history minor should now weigh in). If you want to postulate time travel for a one-time deal, fine, but if you're looking for something that could actually be produced 20 years earlier and be supported for the long term, it just ain't gonna happen. Guy |
![]() "Guy Alcala" wrote in message . .. No, and just as importantly, they probably couldn't produce fuel of sufficiently high octane to allow it to produce the higher power it's capable of, even if they could build the engine, and chances are the oil would be inadequate as well (petroleum engineers with a history minor should now weigh in). If you want to postulate time travel for a one-time deal, fine, but if you're looking for something that could actually be produced 20 years earlier and be supported for the long term, it just ain't gonna happen. Guy Simple, just put some information on how to make a catalytic cracker in the cockpit. -E -- To reply, get the 5 out as if I were my own ISP. |
"Eric Boyd" writes: "Guy Alcala" wrote in message . .. No, and just as importantly, they probably couldn't produce fuel of sufficiently high octane to allow it to produce the higher power it's capable of, even if they could build the engine, and chances are the oil would be inadequate as well (petroleum engineers with a history minor should now weigh in). If you want to postulate time travel for a one-time deal, fine, but if you're looking for something that could actually be produced 20 years earlier and be supported for the long term, it just ain't gonna happen. Guy Simple, just put some information on how to make a catalytic cracker in the cockpit. As pointed out in my reply to Guy's post, fuel quality wasn't the problem. -- Pete Stickney A strong conviction that something must be done is the parent of many bad measures. -- Daniel Webster |
Guy Alcala writes: Charles Talleyrand wrote: "Eunometic" wrote in message om... My feeling is that knowledge of materials for engine development was what kept engine weight up and kept down the performance of most of these aircraft. For instance an engine of the quality of the cyclone seen on Charles Lindbergs Spirit of St Louise would have immeasurably improved the performance of these aircraft especially if fitted with NACA style cowlings. It most certainly was easily buidable by the fabrication techniwques of the day. Prior to that engines were bulky liquid cooled models or clumsy rotaries. Suppose someone gives them a construction manual and a prototype of a radial engine (probably without the turbocharger) for any common radial engine of the 1940s. Can they get the correct alloys and build to the needed tolerances? No, and just as importantly, they probably couldn't produce fuel of sufficiently high octane to allow it to produce the higher power it's capable of, even if they could build the engine, and chances are the oil would be inadequate as well (petroleum engineers with a history minor should now weigh in). Not a Petroleum Engineer, but some of teh vehicles in the Family Collection date from that period (In particular, the FWD 3-5 Ton Truck, and the Van Dorne 6-ton Tank (Renault FT). The Gasoline back then was a lot better than most people think - it was a byproduct of Kerosene production, and they'd basically boiled & squeexed anything that wasn't Iso-Octane out in order to maximize the yeld for teh other products. Of course, here aren't any good samples lying around, but I'd place teh Octane Rating at somewhere above 80, so it wouldn't be too dissimilar from 80/87 AVGAS. Materiels werent' a problem either - The Engine Block, Intake Manifolds, Transmission and Transfer Case on the FWD are Alumin(i)um, and nearly pure at that - (I took a sample to the Materiels Lab when I was working for the World's Largest Producer of Consumer Batteries and checked it out) much better than most Aluminum stock these days, but probably as expesive as All Get Out. A lot of that Octane Rating was wasted, though. Because of the need to actually get the thing started, and because the Electric Motors of teh day weren't up to it, the maximum Compression Ratio that was practical to use was around 4-4.5:1. (It took 3 guys to prop a 1650 cu-in Liberty, for example, and the 400 Cu-in on the FWD is a serious workout, even with an Impulse unit on teh Magneto to help) Note that this wasn't just confined to the 1910-1920s - many engines used flywheel starter systems, either hand-cranked or electrically driven, to store up enough energy to get the bit engines turned over. The big drawbacks to producing a high-powered engine at that time were Carburetion and Ignition. Carburetoes were simple in the extreme, adn weren't very good at atomizing fuel, or at adjusting to the varying air densities encountered by an airplane engine. Ignition systems were crude - they all worked with extremely high voltage, (70 Kvolts or so), to try to get the strongest spark they could, with the Spark Plugs that existed at that time. That's all well and good, but there weren't any good insulators available. This led to internal breakdowns in the Magnetos, and arcing and shorting of the plug leads. It's bad enough at Sea Level, and it's horrid at high altitude, where the dielectric properties of the air are much worse. (Heat tolerance by these materials was poor, as well.) Insulators were ceramic, Natural Rubber, and Mica. It took the development of Plastics in the late 1920s-early 1930s (Most Notably Bakelite and Formica) to produce reliable high-power Ignition Systems. If you want to postulate time travel for a one-time deal, fine, but if you're looking for something that could actually be produced 20 years earlier and be supported for the long term, it just ain't gonna happen. Concur - there were a lot of steps that had to be made before you could build anything more advanced than they were. In fact, teh Forst World War, and the technology race that it spawned was the major driver for those advances. -- Pete Stickney A strong conviction that something must be done is the parent of many bad measures. -- Daniel Webster |
Peter Stickney wrote:
In article , Guy Alcala writes: Charles Talleyrand wrote: "Eunometic" wrote in message om... My feeling is that knowledge of materials for engine development was what kept engine weight up and kept down the performance of most of these aircraft. For instance an engine of the quality of the cyclone seen on Charles Lindbergs Spirit of St Louise would have immeasurably improved the performance of these aircraft especially if fitted with NACA style cowlings. It most certainly was easily buidable by the fabrication techniwques of the day. Prior to that engines were bulky liquid cooled models or clumsy rotaries. Suppose someone gives them a construction manual and a prototype of a radial engine (probably without the turbocharger) for any common radial engine of the 1940s. Can they get the correct alloys and build to the needed tolerances? No, and just as importantly, they probably couldn't produce fuel of sufficiently high octane to allow it to produce the higher power it's capable of, even if they could build the engine, and chances are the oil would be inadequate as well (petroleum engineers with a history minor should now weigh in). Not a Petroleum Engineer, but some of teh vehicles in the Family Collection date from that period (In particular, the FWD 3-5 Ton Truck, and the Van Dorne 6-ton Tank (Renault FT). The Gasoline back then was a lot better than most people think - it was a byproduct of Kerosene production, and they'd basically boiled & squeexed anything that wasn't Iso-Octane out in order to maximize the yeld for teh other products. Of course, here aren't any good samples lying around, but I'd place teh Octane Rating at somewhere above 80, so it wouldn't be too dissimilar from 80/87 AVGAS. Pete, thanks for jumping in. I had/have a vague memory of reading that WW1 Avgas was around 60 octane, but that could be way off. However, see below. Materiels werent' a problem either - The Engine Block, Intake Manifolds, Transmission and Transfer Case on the FWD are Alumin(i)um, and nearly pure at that - (I took a sample to the Materiels Lab when I was working for the World's Largest Producer of Consumer Batteries and checked it out) much better than most Aluminum stock these days, but probably as expesive as All Get Out. A lot of that Octane Rating was wasted, though. Because of the need to actually get the thing started, and because the Electric Motors of teh day weren't up to it, the maximum Compression Ratio that was practical to use was around 4-4.5:1. (It took 3 guys to prop a 1650 cu-in Liberty, for example, and the 400 Cu-in on the FWD is a serious workout, even with an Impulse unit on teh Magneto to help) Note that this wasn't just confined to the 1910-1920s - many engines used flywheel starter systems, either hand-cranked or electrically driven, to store up enough energy to get the bit engines turned over. The big drawbacks to producing a high-powered engine at that time were Carburetion and Ignition. Carburetoes were simple in the extreme, adn weren't very good at atomizing fuel, or at adjusting to the varying air densities encountered by an airplane engine. Ignition systems were crude - they all worked with extremely high voltage, (70 Kvolts or so), to try to get the strongest spark they could, with the Spark Plugs that existed at that time. That's all well and good, but there weren't any good insulators available. This led to internal breakdowns in the Magnetos, and arcing and shorting of the plug leads. It's bad enough at Sea Level, and it's horrid at high altitude, where the dielectric properties of the air are much worse. (Heat tolerance by these materials was poor, as well.) Insulators were ceramic, Natural Rubber, and Mica. It took the development of Plastics in the late 1920s-early 1930s (Most Notably Bakelite and Formica) to produce reliable high-power Ignition Systems. If you want to postulate time travel for a one-time deal, fine, but if you're looking for something that could actually be produced 20 years earlier and be supported for the long term, it just ain't gonna happen. Concur - there were a lot of steps that had to be made before you could build anything more advanced than they were. In fact, teh Forst World War, and the technology race that it spawned was the major driver for those advances. Googling found this: www.enginehistory.org/OX5to3350.pdf aka "OX-5s to Turbo-Compounds: A Brief Overview of Aircraft Engine Development", covering roughly 1920-1950. It basically says that improvements were made more or less concurrently in seven areas, fuel being one of them. It also states that "early" [no idea what period, but presumably pre-1920] gasoline had octane ratings from 25-50. Guy |
FS: 1988 "Aces High" (Military Airplanes) Hardcover Edition Book | J.R. Sinclair | Aviation Marketplace | 0 | August 23rd 04 05:18 AM |
Ever heard of Nearly-New Airplanes, Inc.? | The Rainmaker | Aviation Marketplace | 1 | June 23rd 04 05:08 PM |
SMALLL airplanes.. | BllFs6 | Home Built | 12 | May 8th 04 12:48 PM |
FS: 1990 Cracker Jack "War Time Airplanes" Minis 6-Card (CJR-3) Set | J.R. Sinclair | Aviation Marketplace | 0 | April 12th 04 05:57 AM |
Sport Pilot Airplanes - Homebuilt? | Rich S. | Home Built | 8 | August 10th 03 11:41 PM |
