Radios with fixed, pre-set frequencies (Walter Dittel FSG16). Why?
Old February 8th 16, 01:43 PM posted to rec.aviation.soaring
Surge
Default Radios with fixed, pre-set frequencies (Walter Dittel FSG16). Why?
On Monday, 8 February 2016 15:29:53 UTC+2, Tango Whisky wrote:
The FSG16 is an almost 40 years old design. At the time, the channels/frequencies were stabilized with one dedicated quartz per frequency, and the FSG16 was designed to hold 12 quartzes. Simple as that.
So 12 individual crystals was a cheaper solution than being able to tune into any of the 720 usable channels that the rest of the receiver unit is capable of?
Old February 8th 16, 02:40 PM posted to rec.aviation.soaring
Correct, same for many radios (including RC radio's). The hardware could cover a wide range, but it was the crystals that did the actual tuning.
Later radios did all this without "crystals" and could also do smaller steps in between freq's.
Old February 8th 16, 02:57 PM posted to rec.aviation.soaring
Ross[_3_]
It's basically the same sort of question as to why did my first tv only have 4 preset channels?
Why was it black and white?
Tech has developed a long way in 40 years.
If you are looking to upgrade just a little, I can offer you a Dittel FSG40s. Just removed from my Libelle, and I am guessing it was new with the ship.
Old February 8th 16, 04:14 PM posted to rec.aviation.soaring
Paul Ruskin[_2_]
A few years ago the radio in my ASW20 had problems. I took it out and took it apart.
It had the ability to store four frequencies in it (which you could set). To do this it had a couple of large chips which turned out to be memory. Each chip's capacity was 32 bits. Not Megabits. Not Kilobits. Bits.
State of the art at the time, I suspect.
When I was a lad....
Old February 8th 16, 09:21 PM posted to rec.aviation.soaring
Back in the 80s, I built a couple of RST radios from kits. Light, dependable, decent range. But crystal controlled. I bought 123.3 and 123.5 with the kit. I wanted to add a frequency later so I had to buy another crystal (two, IIRC, for transmit and receive?). There were 10 slots but I didn't fill them all up. This was back when an aviation set had 360 frequencies.
Technology marches on.
Chip Bearden
Old February 9th 16, 12:16 AM posted to rec.aviation.soaring
Stephen Damon
Just buy your club a radio that you want it to have like 1000 watt Becker and help them out.
Old February 10th 16, 09:00 PM posted to rec.aviation.soaring
Six-Seven Romeo
The idea of one quartz crystal per frequency is as old as some of the earliest radios (think "crystal" radio set). And, yes, it was cheaper, at least at first but obviously very limited in functionality. Radio Shack carried all sort of crystal so that you could retune your police scanner based on your locale. As an aisde, my club has two Dittel base stations (battery and AC powered) that are based on panel mounted Dittel radios. One radio is an FSG60M which has a four channel "memory" manually set by some large rotary switches on the top. Never saw that before. You can see pictures of this radio at http://aviation.derosaweb.net/transceivers/dittel/.
Old February 14th 16, 12:09 AM posted to rec.aviation.soaring
AS
My Libelle came with a US-made radio that held 4 frequencies and you had to tune the receiver to the frequency you were transmitting on. Now that was old-school stuff!
Uli
AS
Old February 13th 16, 03:07 PM posted to rec.aviation.soaring
Soartech
No, not cheaper. It just wasn't invented yet. The old radios were all analog. Today they are mostly digital. They use just one quartz crystal and they mathematically change that one frequency to any number you need. These are called "frequency synthesisized" radios. Yes, they are way cheaper than all those custom cut crystals.
walter Dittel fsg 2t shkdriver Soaring 3 January 4th 16 08:26 AM
Walter Dittel FSG-50, 60, 60M [email protected] Soaring 1 November 7th 14 07:42 AM
Who repairs Dittel radios? Steve Koerner Soaring 8 August 22nd 14 07:13 PM
Wanted: Walter Dittel FSG60M [email protected] Soaring 0 April 21st 08 02:06 AM
Walter Dittel Radios Nyal Williams Soaring 3 December 30th 07 06:52 AM
