Newest Sailplane in the world on display at the 2016 SSA convention
Old February 9th 16, 03:13 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Default Newest Sailplane in the world on display at the 2016 SSA convention
Couple of reasons for the "hard bends".
1. Manufacturing. Yes, you could do it as smooth, flowing curves since the molds are now machine cut. But, it is more difficult to fit and press together long, flowing curved joints than a series of straight line joints. You also notice that most wings have distinct taper breaks, and not the "elliptical" planform (SZD-55, PW-5 and PW-6 are exceptions).
2. Ease of repair or refinish. Ever try to make a sanding board to perfectly blend a re-pair or refinish on a continuously varying radius, 3D part?
The changes in dihedral are small enough to not cause any significant issues. Similar to the changes in taper ratio at a taper break. Yes, there is a change in the pressure field around the wing at each of these, but there is negligible impact until you get to much larger changes in taper ratio or dihedral than are used here.
To my mind, the real benefits of the changes in dihedral come about in the outer at most 1/3rd of the semi-span, where you can make the downwash field behind the wing work to keep the tip votrex from shrinking the span of the downwash field.
But, that is just my opinion.
Steve Leonard
Old February 9th 16, 03:55 PM posted to rec.aviation.soaring
Andy Blackburn[_3_]
I always thought the discrete breaks in dihedral and taper were primarily so the control surfaces could have straight hinge lines that didn't bind.
I suspect the other reasons are also true.
9B
Old February 9th 16, 04:47 PM posted to rec.aviation.soaring
smfidler
I'm starting to feel as if I'm at some boy band concert watching the girls screaming uncontrollably at the lead singer from the front row...
Just like the JS-1 camp learned, out designing the ASG-29 in all conditions and at all wing loadings is a very, very high bar to jump over cleanly.
Here is a towel.
Stop drooling all over yourselves and let's see if the V3 wins the 18 meter World Championship in Australia next January before loosing consciousness, screaming like school girls the latest, greatest boy band concert...
The V3 'might' just win the Worlds on its first go and even become a truly dominant 18m glider, but until it does, it's marketing hype. They will employ a surge of top pilots (disproportional distribution) trying to win their first worlds (see Quintus) and seal in the marketing investment. JS-1 tried this too but never made it over that pesky "ASG-29 bar." Pilots often trump a gliders true performance. Keep an eye on this.
Many, quite recently in fact, thought the JS-1 would dominate the ASG-29...but it has not. Only very recently, with the new EVO design, has the JS-1 begin to challenge the 29. And the JS1 has never won a FAI world championship against the enviable ASG29. Not once (well, if you count the last SGP World Championship,yes, but there was a valid wing loading fairness controversy at that smaller event)!
And, even if the V3 does prove a match or better, Schleicher will simply draw up a new 18 meter glider specifically intended to make the V3 obsolete, and so on... Maybe Schleicher is already well down the track on this new design already... Maybe they can simply improve the 29 with a new wing design like the JS-1 camp has with the new JS-1 Evo.
One thing is certain, the glider manufactures have you all right where they want you...buzzing wildly over almost nothing, fighting to hand over 200k checks in order to own (years from now) an unproven glider which many somehow absolutely (almost religiously) believe is sure to allow them to beat the pants off anyone flying the ASG-29 via its massive performance advantages.. Good luck with this gentleman. I for one have seen this cycle many times before in many sports.
And, if the V3 is somehow completely unstoppable in 18 meter (as you suggest), we already have so many ASG29s in the USA that we could "put our hands up" and start a "29 ONLY class" (much less expensive than buying (and waiting for) a new V3 and all with identical performance while being well proven machines!). One design 18 meter the racing! ;-). It will be 5 years, minimum, before the V3 US numbers approach a third of the 29s. And that 1/3 number is only in a perfect world for Shempp Hirth, with no hiccups or issues with the design. You V3 "bling, bling" glider guys (if it's ridiculously better) might just have to fly in open class again the Concordia! :-)
So, I'm excited to see the V3 at the convention (and the buzz surrounding it) but won't be interested until it clearly proves that it is a significantly better (or even equal) sailplane to the ASG29 and the JS1 Evo in a wide range of conditions. Until it proves its worth with contest results. And even then, rather than jumping at it immediately, I'll be looking to see the reaction from the other manufacturers.
Amused and thoroughly enjoying the "screams and shouts of glee" from the SH fan boys...
Sean
Old February 9th 16, 04:59 PM posted to rec.aviation.soaring
smfidler
And technically, the GP14 is a newer, far more innovative design. It has the potential to really grow the sport.
http://www.gpgliders.com/gp-14-velo-0
Powerful electric self launch w/o the FES propeller drag, 45:1, flapped 13.5 meter. Light, small and easier to manage.
Roughly 80k complete (yes, COMPLETE) with trailer. Even better if you order at the convention. That is simply incredible pricing.
I would be even more excited to see this little puppy at the convention floor! I already know what a SH wing with a Maumer winglet looks like. ;-)
Sean
Old February 9th 16, 05:12 PM posted to rec.aviation.soaring
Tim[_11_]
Sean
Thanks for the props for this glider Sean! Things are shaping up nicely for this glider and, as you say, the price/performance with self-launch capability is pretty spectacular. Promotional pricing is still available for early adopters!
Unfortunately, Innovation and High Quality take longer than the oringinal very aggressive ambitions of this young glider manufacturer. Things are progressing very well at the factory and they are putting the finishing touches on the prototype for first flight very "shortly". If someone could give a call to the weather gods of southeastern Poland, everyone involved would appreciate it. While a GP 14 will not be on the floor of this convention, please stop by the GP Gliders USA booth at the convention to learn more and pickup some cool schwag.
Tim McAllister
GP Gliders USA
Old February 10th 16, 03:25 PM posted to rec.aviation.soaring
HGXC[_4_]
Sean
Sean ...do you have some sort of hard on for SH?...I celebrate all new designs because it helps advance the R&D of gliding. Why the pale of cold water?
Dennis
Old February 10th 16, 04:10 PM posted to rec.aviation.soaring
smfidler
Not cold water. Just a cool breeze of clam and patience.
I think the nemerous deposits and absolute belief in the performance predictions (every new glider makes them) is quitepremature. I think the V3 is going to run well, but will it climb in weak lift? Will it be able to carry water early in the day? Will it handle? Have they made their compromises properly and was their data analysis of 18 meter contest behavior (speeds, running, climbing percentages) accurate?
All the little things make a glider truly great (see 29). The Arcus is good, but really has had not true performance competition until last year with the 32. Unlike the Arcus which was entering a new class (flapped 20m 2 place), the V3 is entering the worlds most competitive class. The 29 is enormously strong and the JS-1 has been significantly improved (although very good from the early stages). The V3 really has to be Newley perfect to be demonstrably better than those gliders in all conditions. Is it a "me too" or is it truly innovative as they contend.
The V3 might, for example, end up being great in strong conditions and weak in others. I also question if they will build them light enough. I also worry about the cockpit size.
We shall see. I hope it's great. But yes, not too great. I would love to not have to buy a new glider to be competitive. The current 18 meter balance is actually really great between the 29, JS1 and V2. A new, unbeatable 18 meter glider could hurt the class more than it helps it, initially. I'm all for supporting the builders. But many will probably not want to buy a new glider just to be somewhat competitive in a class.
If the V3 end up being a requirement to play in 18m, yes, I'll buy one...if Scheicher des not rapidly respond. Lots of if's....
And yes, the V3 wing is very pretty. But I would buy an ugly wing if it was better! I still like th 29 right now. The 29 fuselage shape is beautiful, and it's cockpit is incredibly comfortable and functional. It's resilient, easy to fly and really strong at high wing loading. If the V3 is only equal, I would likely keep the 29 for some time.
Old February 10th 16, 08:36 PM posted to rec.aviation.soaring
Luke Szczepaniak
Default Newest Sailplane in the world on display at the 2016 SSAconvention
Not the first words that pop up in my mind when I read "internet Sean's"
posts ;-)
Luke
Old February 9th 16, 07:38 PM posted to rec.aviation.soaring
Jonathan St. Cloud
I would be interested to know if the fuselage is the same from the V2CX series, the canopy is side hinged. is it the same Vertical fin airfoil, same horizontal? Are the wings turbinated with blow holes or zig zag tape?
I purchased a V2C waited two years to get it then 6 weeks after I got the V2C licensed and in the air the V2CX was announced, I was very unhappy. If the New Ventus is the same fuselage and tail feathers as to V2CX, then I wonder how long before the New Ventus X is announced.
Here is a towel.
Many, quite recently in fact, thought the JS-1 would dominate the ASG-29....but it has not. Only very recently, with the new EVO design, has the JS-1 begin to challenge the 29. And the JS1 has never won a FAI world championship against the enviable ASG29. Not once (well, if you count the last SGP World Championship,yes, but there was a valid wing loading fairness controversy at that smaller event)!
One thing is certain, the glider manufactures have you all right where they want you...buzzing wildly over almost nothing, fighting to hand over 200k checks in order to own (years from now) an unproven glider which many somehow absolutely (almost religiously) believe is sure to allow them to beat the pants off anyone flying the ASG-29 via its massive performance advantages. Good luck with this gentleman. I for one have seen this cycle many times before in many sports.
Sean
Old February 9th 16, 08:05 PM posted to rec.aviation.soaring
K m
Here is a towel.
Sean
Sean,
I think we are all a little upset since Zane left One Direction but lets get a hold of ourselves. You are talking a bunch of straw man silliness. I didn't know "Everyone" thought the JS would dominate and you have to admit it has produced some good results at the World level. It also has the ability to fly at 21M. Perhaps SH just realized that with a Decades old planform and wing and fuse profile it was time for an update. And "Technically" the GP14 is just a shiny mock up and until it flys and proves the numbers and enters serial production I'll rely on an 80 YO company. I am a Lifelong Schleicher Man myself, (K21,20,and 27) but I will try the V3 on for size at the convention and am considering buying a slot. I promise not to jump up and down with glee.
Newest Sailplane in the world on display at the 2016 SSA convention Renny[_2_] Soaring 4 February 8th 16 10:35 PM
Used Sailplanes for sale & On Display at the 2016 SSA Convention SF Soaring 7 February 7th 16 04:51 PM
What to do at the 2016 SSA convention, besides the conventon SF Soaring 3 February 7th 16 04:24 PM
2016 SSA Convention Presentations Jonathan St. Cloud Soaring 10 February 5th 16 07:55 PM
2016 SSA Convention Website is up [email protected] Soaring 3 September 14th 15 06:35 PM
