Newest Sailplane in the world on display at the 2016 SSA convention
Old February 10th 16, 04:10 PM posted to rec.aviation.soaring
smfidler
Default Newest Sailplane in the world on display at the 2016 SSA convention
Not cold water. Just a cool breeze of clam and patience.
I think the nemerous deposits and absolute belief in the performance predictions (every new glider makes them) is quitepremature. I think the V3 is going to run well, but will it climb in weak lift? Will it be able to carry water early in the day? Will it handle? Have they made their compromises properly and was their data analysis of 18 meter contest behavior (speeds, running, climbing percentages) accurate?
All the little things make a glider truly great (see 29). The Arcus is good, but really has had not true performance competition until last year with the 32. Unlike the Arcus which was entering a new class (flapped 20m 2 place), the V3 is entering the worlds most competitive class. The 29 is enormously strong and the JS-1 has been significantly improved (although very good from the early stages). The V3 really has to be Newley perfect to be demonstrably better than those gliders in all conditions. Is it a "me too" or is it truly innovative as they contend.
The V3 might, for example, end up being great in strong conditions and weak in others. I also question if they will build them light enough. I also worry about the cockpit size.
We shall see. I hope it's great. But yes, not too great. I would love to not have to buy a new glider to be competitive. The current 18 meter balance is actually really great between the 29, JS1 and V2. A new, unbeatable 18 meter glider could hurt the class more than it helps it, initially. I'm all for supporting the builders. But many will probably not want to buy a new glider just to be somewhat competitive in a class.
If the V3 end up being a requirement to play in 18m, yes, I'll buy one...if Scheicher des not rapidly respond. Lots of if's....
And yes, the V3 wing is very pretty. But I would buy an ugly wing if it was better! I still like th 29 right now. The 29 fuselage shape is beautiful, and it's cockpit is incredibly comfortable and functional. It's resilient, easy to fly and really strong at high wing loading. If the V3 is only equal, I would likely keep the 29 for some time.
Old February 10th 16, 08:36 PM posted to rec.aviation.soaring
Luke Szczepaniak
Default Newest Sailplane in the world on display at the 2016 SSAconvention
Not the first words that pop up in my mind when I read "internet Sean's"
posts ;-)
Luke
Old February 10th 16, 10:24 PM posted to rec.aviation.soaring
posts ;-)
Luke
Hey, Internet Sean is, "Happy as a clam" on new sailplanes...... or, did he mean to post "calm"???
[BTW, what is a "cool breeze of clam"?, a winter "passing of gas" from a bivalve?]
/sarcasm......
[I really HATE peeps that use small devices with "auto-complete" and then don't read BEFORE posting...... things can make a whole lot of difference after posting...., say's the "technophobe".....]
LOL....
There is always the, "Next great thing", marketing types always trumpet the advances, it's their job.
I've worked decades in service & manufacturing, I'm usually stuck between what "Sales sells" and what "engineering can provide within the costs".
I'm usually part of the phone calls that ask, "Why doesn't it do what I was told it would do?!".
As an aside, I wonder how much traction a 13.5 meter class will actually gain. Not the 1st time someone has pushed a "one design class". Only really good example is the SGS-1-26 class, basically the rest were, "Good ideas that went nowhere."
Old February 10th 16, 11:15 PM posted to rec.aviation.soaring
Tony[_5_]
The 13.5 meter class, like all of the other FAI classes (now), is not a one design class...
Old February 10th 16, 11:56 PM posted to rec.aviation.soaring
While you are correct, it "appears" to me that it is a direction some are going for.
Unless the handicap is good/one design class, why would you buy one unless it's NOT contest related?
It may be a great, "Get into soaring/XC soaring" sailplane for not a lot of money, but if you decide to do contests (outside of a one design class), what is the point?
Yes, I'm wearing Nomex underwear, flame away.
Not saying to avoid this or other sailplanes in this range, sorta depends on what you're looking for.
A "new design, no worries on NDH/NDDH issues, no AD's [in the US], warranty, etc." is a GREAT thing.
Buy away.
But, what is YOUR ultimate goal?
This could be a great way to "get your feet wet" on XC, fly a handicapped contest (yes, contest, NOT race.....) and decide where you want to go next.
It may even be the, "Modern SGS-1-26" to get peeps going away from the local airport.
Fantastic.
Old February 11th 16, 03:02 AM posted to rec.aviation.soaring
smfidler
On Wednesday, February 10, 2016 at 6:56:44 PM UTC-5, Charlie M. (UH & 002 owner/pilot) wrote:
Buy away.
Fantastic.
Sorry gents, my internet thumbs and rushing to type fast on a phone really blew that post up badly. Im just going to give up on that one...
Old February 11th 16, 08:34 AM posted to rec.aviation.soaring
krasw
ASW27 and V2 have a wing profile from mid 90's. ASG29 has basically modified tips, which naturally have to follow the original profile.
V3 has 2 decades more worth of aerodynamical knowledge in it's design. One can speculate how much has happened during last 20 years but at least there is a great chance that something has.
Performance increase from one generation to next tends to be small but noticeable, otherwise you wouldn't design and build new gliders. For SH, all it takes is glider buying pilots believe that it will be better than 29. There are lot of pilots who tend to stick with one factory product and they surely have jumped already in que for V3.
One thing that bothers me is (6ft5') the fact that SH still sticks with fuselage built for dwarfs in a age when average size of people is something else. Would you buy new 200k glider with too big fuselage, knowing that similar glider with too small fuselage is better? Other one is FES blades sticking in the wind. The system is great, but when aiming to world's podium it just isn't the way to go. Unless they manage to fair the blades in some way (should be doable).
Old February 11th 16, 08:22 AM posted to rec.aviation.soaring
Kevin Neave[_2_]
To have fun & enjoy soaring & flying XC.
Too many people are getting hung up on absolute levels of performance. Look
at the fun the club class are having.
In my case I wanted an Electric Sustainer.
Electric for reliability, and someone has to be an early adopter.
Only needs to be a sustainer to get me away from a farmers field to
hopefully a more friendly reception at an airfield.
Being electric limits the amount of "fuel" on board so minimum drag with
the engine running means FES appeals more than "engine on a stick".
(I've already owned a Discus bT for 10 years so been there done that on the
"Engine on a stick")
My preference would have been for a FES modification to my Discus B, but
too many hurdles in EASA land. I'm not aware of any FES modified sailplanes
in USA where things are apparently easier.
Most of the people I fly with have Discus / LS4 / ASW20 level of
performance so would have liked to avoid going up to 18m
Resale values mean Schempp or Schleicher.
The option I've gone for is the D2c FES, I'm prepared to take the hit on
the FES "penalty", my inability to keep the string in the middle is
probably a much greater issue anyway.
In 5-10 yrs time when we decide to replace the Discus bT I'll have another
look at the GP series.
KN
unless
Old February 11th 16, 09:10 AM posted to rec.aviation.soaring
Comparing the FES to the GP14 folding prop/ pylon design I would hazard a guess that better propellor performance in the GP14 design will negate any detriment from pylon drag.
Newest Sailplane in the world on display at the 2016 SSA convention Renny[_2_] Soaring 4 February 8th 16 10:35 PM
Used Sailplanes for sale & On Display at the 2016 SSA Convention SF Soaring 7 February 7th 16 04:51 PM
What to do at the 2016 SSA convention, besides the conventon SF Soaring 3 February 7th 16 04:24 PM
2016 SSA Convention Presentations Jonathan St. Cloud Soaring 10 February 5th 16 07:55 PM
2016 SSA Convention Website is up [email protected] Soaring 3 September 14th 15 06:35 PM
