If it's rated for use as a switch, sure you can use a breaker as a switch. I have a Tyco breaker that's rated as a switch (looks like a toggle switch) that I bought because when I was planning a FLARM install that was integrated with an LX8080 Simple/V5 I wasn't sure whether the LX delivered switched or unswitched power to the FLARM. As it turned out it delivered switched power so the breaker is on my shelf rather than in the glider. The glider has two aircraft spec breakers on the panel and one built into the battery box. My glider no longer has any master switch as all the avionics have their own built in on/off switches so the only thing the master switch did for me was to present me with the possibility of turning everything off in flight by accident.
Good Idea? | Little Luke | Piloting | 1 | August 20th 08 04:22 PM |
Pilots Uniform: Good idea?? | [email protected] | Owning | 16 | December 6th 07 07:44 PM |
"Trying out" a different insturctor just to see - good idea? Badidea? | GEG | General Aviation | 18 | May 8th 05 08:33 PM |
Is replacing Maverick with JCM a good idea? | Scott Ferrin | Military Aviation | 12 | June 16th 04 10:07 PM |
Defrag before install a good idea? | Mark Cherry | Simulators | 3 | September 23rd 03 07:51 AM |
