IS-28B2 Twin Lark - Service Life Extension Program
Old February 25th 16, 09:24 PM posted to rec.aviation.soaring
JS
Default IS-28B2 Twin Lark - Service Life Extension Program
I just saw this posted by Mandy Temple, President of the Gliding Federation of Australia.
This approval may just be for operation in Australia, but even if so is a start.
IS28 Life Extension
There is now a simple method to extend the life of IS28 gliders beyond 35 years. Rob Hanbury, with help from a young pilot Bogdan Hiticas, has set up a system piggybacking off the Romanian EASA approval. For more information contact Rob Hanbury Airworthiness Department Chair
CAD at glidingaustralia dot org
  #52
Old February 25th 16, 10:27 PM posted to rec.aviation.soaring
IS28 Life Extension
Thanks Jim. I have sent an email to Rob. Also waiting to hear from Peter Whitehead.
  #53
Old February 29th 16, 04:39 PM posted to rec.aviation.soaring
IS28 Life Extension
HELLO ALL
At this time there is a Supplemental Type Certificate issued no. 10054289
http://easa.europa.eu/system/files/d...t_20151208.pdf
I own a IS28B2 as as we speak I am apllying the life extension.
For more informations you cand get in touch with the Romanina Airclub
They are the holder of this suplement and there might in the future get to be the holders of all the IS 28 and 29 type certificates.
Regards Alin from ROmania
  #54
Old March 2nd 16, 07:09 AM posted to rec.aviation.soaring
Peter Whitehead
Hi, Pete ("edenpete") from UK here. Good news.I have been invited to apply to the Rumanian Aeroclub for the package related to their STC to extend the life of my IS-28B2("Lark" 2-seater). This will cost 500 Euro (glider specific, based on serial number). This will be necessary for all EASA gliders, it will be up to your own country's technical organisation to decide what steps it wishes to take regarding this, if outside EASA.
Good luck. Pete
  #55
Old March 4th 16, 04:18 PM posted to rec.aviation.soaring
Good luck. Pete
Hello Pete, thanks for the update. I am wondering if there is a chance of obtaining a copy of the IS29D2 Service Bulletin that you received from the Romanian Aeroclub for our review and presentation to Transport Canada in defense of a privately owned IS29D2 that has now been grounded. Thanks, Mike
  #56
Old March 5th 16, 10:05 AM posted to rec.aviation.soaring
Peter Whitehead
Good luck. Pete
Mike, I shall send some photocopies (re IS29 SB) by post if you give me your address. I have emailed you direct. Pete
  #57
Old April 17th 16, 03:10 PM posted to rec.aviation.soaring
IA DPE
Any word if the U.S. FAA is working to accept the Romanian Service Bulletin extending the Service Life?
  #58
Old April 25th 16, 01:05 PM posted to rec.aviation.soaring
IS28 Life Extension
HELLO ALL
Job DONE
My IS 28B2 sn 229 flyes again.
Cost:
500 euro - the pice of paper that is S/N specific
640 euro - structure and corrosion control.
Please be advised that at the joint of the vertical stabilizer many IS 28B2 gliders were found to have a crack after 35 years of service. Inspection and action is to be taken for obvious safety reasons.
Mine was exported in Hungary and there there was a program to reinforce that specific joint on all Hungarian IS 28B2 imported so all is ok, but the ones that were not reinforced need to be inspected.
Living in Romania I performed the initial mandatory 2 year inspection with the Romanina Airclub and got a clean bill of health.
Now I can fly it again safely and legally.
  #59
Old May 5th 16, 07:39 AM posted to rec.aviation.soaring
Hello Gentlemen.
I write You from Estonia. Our club owns IS30 manufactured 1985 year.
Does anyone knows contacts where to ask about Life Extension program?
Is there program for IS30 glider at all?
Waiting Your response!
Best regards!
  #60
Old May 23rd 16, 11:33 AM posted to rec.aviation.soaring
Do you have an amendment number or "more text" about the reinforcement of the joint?
IAR IS-28B2 Twin Lark Manuals Needed Markus Graeber Soaring 3 July 8th 12 10:54 AM
Lark life extension lanebush Soaring 7 March 17th 10 03:50 AM
Grob 103 Twin II Life Extension Mike McCarron[_2_] Soaring 2 May 18th 09 01:15 PM
Grob 103 Twin II Life Extension Mike McCarron[_2_] Soaring 2 May 18th 09 02:49 AM
IS-28B2 Twin Lark status Greg Arnold[_2_] Soaring 4 June 17th 08 03:34 PM
