On Sunday, February 28, 2016 at 4:15:13 AM UTC-8, Paul Birkett wrote:
Hello, my intention is to fit a Transponder Antenna within my ASW27. I was wondering does anyone know where on the ASW27 Fuselage is not Carbon or Aramid(conductive) construction, which would allow internal fitting of an antenna such as a Dolba BD1, Dolba BD2, FUNKE DP1090-5 or similar? Schleicher TM/TN 13 "installation of a PCB-transponder antenna in the vertical tail" doesn't give a drawing/photo/diagram and I have requested additional information from Zulu-Glasstek. If I were to install antenna within the vertical stabilizer (Dolba BD1), the coax cable length would be considerable (6 to 7 metre) and routing-security could be an issue, using Carlisle ECS P/N 311501 coax cable. However, if the nose (tip area) of the fuselage was manufactured from GRP as maybe used on other carbon fibre Schleicher fuselages, then I would endeavour to install antenna within this area? I have 95% dismissed TM/TN 12, installation of external antenna alongside undercarriage due to it being ugly and prone to damage. Any information gladly received. Best regards Paul. You can often determine what is carbon vs. kevlar or white glass by shining a strong light through it. Carbon is opaque, gel coat/glass less so. On a 26 which has a very similar fuselage, I installed a dipole inside of the nose ahead of the rudder pedals. It tests fine from all angles, and return is reported good from many contacts in the air. No drag, no possibility of breaking it off ground handling. There are some who considered this a heretical install, so you will have to decide for yourself. |
ASW27 Fuselage Tank | Ross Drake | Soaring | 1 | April 25th 13 10:58 AM |
ASW 27 or 27-18 406 ELT & antenna installation | chipsoars | Soaring | 6 | October 10th 09 04:07 PM |
Rust prevention: Inside fuselage | Michael Horowitz | Home Built | 10 | August 20th 07 10:33 PM |
FLARM antenna installation | Kevin Neave | Soaring | 5 | January 16th 07 06:53 PM |
Looking for an ASW27/28 fuselage | goneill | Soaring | 0 | May 23rd 04 08:41 PM |
