ASW27 Trasponder Antenna Installation Inside Fuselage.
Old February 28th 16, 07:23 PM posted to rec.aviation.soaring
Dan Marotta
Default ASW27 Trasponder Antenna Installation Inside Fuselage.
My LAK-17a has a carbon fuselage. I installed a blade antenna aft of
the gear doors, at about the 5-o'clock position with a ground plane
inside the fuselage. Transponder checks show well over 200 watts
transmitted. I've got a Trig TT22.
On 2/28/2016 9:23 AM, wrote:
On Sunday, February 28, 2016 at 11:20:40 AM UTC-5, Richard wrote:
On Sunday, February 28, 2016 at 5:46:46 AM UTC-8, wrote:
On Sunday, February 28, 2016 at 7:15:13 AM UTC-5, Paul Birkett wrote:
Hello, my intention is to fit a Transponder Antenna within my ASW27. I was
wondering does anyone know where on the ASW27 Fuselage is not Carbon
or Aramid(conductive) construction, which would allow internal fitting of
an
antenna such as a Dolba BD1, Dolba BD2, FUNKE DP1090-5 or similar?
Schleicher TM/TN 13 "installation of a PCB-transponder antenna in the
vertical tail" doesn't give a drawing/photo/diagram and I have
requested
additional information from Zulu-Glasstek. If I were to install antenna
within
the vertical stabilizer (Dolba BD1), the coax cable length would be
considerable (6 to 7 metre) and routing-security could be an issue, using
Carlisle ECS P/N 311501 coax cable. However, if the nose (tip area) of the
fuselage was manufactured from GRP as maybe used on other carbon fibre
Schleicher fuselages, then I would endeavour to install antenna within this
area? I have 95% dismissed TM/TN 12, installation of external antenna
alongside undercarriage due to it being ugly and prone to damage. Any
information gladly received. Best regards Paul.
We have installed the antenna, before TN 12 came out, on the bottom behind the gear. This requires and external ground plane of aluminum formed to match the fuselage contour. It looks better than the TN install and is about 5 times the work. All later ones were done to TN 12.
Nose does not meet required criteria.
FWIW
UH
UH can the ground plane be inside the fuselage and if not why?
Richard
Carbon fuselage so it will be more effective on the outside.
UH
Dan, 5J
ASW27 Fuselage Tank Ross Drake Soaring 1 April 25th 13 10:58 AM
ASW 27 or 27-18 406 ELT & antenna installation chipsoars Soaring 6 October 10th 09 04:07 PM
Rust prevention: Inside fuselage Michael Horowitz Home Built 10 August 20th 07 10:33 PM
FLARM antenna installation Kevin Neave Soaring 5 January 16th 07 06:53 PM
Looking for an ASW27/28 fuselage goneill Soaring 0 May 23rd 04 08:41 PM
