IGC-approval - Naviter Oudie-IGC GPS Flight Recorder
Old March 24th 14, 01:46 PM posted to rec.aviation.soaring
Ian Strachan
Default IGC-approval - Naviter Oudie-IGC GPS Flight Recorder
I am pleased to announce IGC-approval for the Naviter Oudie-IGC GPS Flight Recorder for "all flights" including world records. The IGC-approval document may be downloaded from the FAI/IGC web site or the GFAC web site, see below. A table of all IGC-approved Flight Recorders can also be downloaded from these web sites which has links to the IGC-approval document for each type of Recorder.
There are now 46 different types of IGC-approved Flight Recorders from 18 different manufacturers.
If you own or fly with one of these types of IGC Flight Recorder, you are recommended to download its latest IGC-approval document from one of the web sites given below.
For the GFAC web site:
www.ukiws.demon.co.uk/GFAC
The table of all IGC-approved FRs with links to Approval Documents is at:
www.ukiws.demon.co.uk/GFAC/igc_approved_frs.pdf
This document contains:
(1) a table of all types of IGC-approved Flight Recorders in alphabetical order of manufacturer name, with links to their IGC-approval documents.
(2) a table of Manufacturers of IGC-approved Flight Recorders, in alphabetical order of manufacturer name.
(3) a list of all IGC-approval activity from 1996 to the present day.
(4) a history of IGC GNSS Flight Recording.
For the IGC web site:
http://www.fai.org/gnss-recording-de...ight-recorders
Scroll down to "IGC-Approved Flight Recorders - Approval Documents"
Then click on the box underneath the above heading which says:
"IGC-approval Documents for all IGC-approved Flight Recorders".
This will call up a list of documents, the first one being "IGC-approval tables" with links to individual Approval documents.
This is followed by IGC-approval documents in alphabetical order of manufacturer's name. Scroll down to the Recorder type and click on its name. The IGC-approval document will then download automatically to the directory that you have set for downloads, without being displayed on screen first.
IGC-approval follows test and evaluation by the IGC GNSS Flight Recorder Approval Committee (GFAC) in accordance with Annex B to the Sporting Code for gliding and the Technical Specification for IGC-approved GNSS Flight Recorders.
The Technical Specification is available through the igc-approved-flight-recorders web site above or directly from the GFAC web site:
http://www.ukiws.demon.co.uk/GFAC/do..._spec_gnss.pdf
The Sporting Code for gliding (SC3) and its annexes A-D may be downloaded via www.fai.org/igc-documents
Ian Strachan
Chairman, IGC GNSS Flight Recorder Approval Committee
Old March 26th 14, 07:43 PM
dbrunone dbrunone is offline
Member
First recorded activity by AviationBanter: Oct 2011
So if I have an Oudie-V7-Nano setup, is there any reason to keep to Nano anymore?
Old March 27th 14, 01:00 AM posted to rec.aviation.soaring
Gianni Isotope
anymore?
Yes, the original Oudie and Oudie 2 do not have IGC-approved flight recorders -- only the latest product called "Oudie IGC".
Old March 4th 16, 12:36 PM posted to rec.aviation.soaring
Casey[_2_]
When is the last time the Oudie IGC has been updated (todays date 3/4/16)?
Seems like electronics are outdated after a year or two if not updated. Does the IGC have bluetooth? I could not find this, so is this something Naviter is considering or never will be in IGC? Seems like a lot of electronics have bluetooth.
Old March 4th 16, 01:09 PM posted to rec.aviation.soaring
Minot Moonshiners
I believe it does have bluetooth, but admittedly, I have not tried it yet on mine.
Old March 4th 16, 02:34 PM posted to rec.aviation.soaring
Casey[_2_]
Yes it does appear to have bluetooth. Retailers do not have it listed but I found on Naviter site via support.
IGC-approval for the FlarmMouse Flight Recorder Ian Strachan Soaring 0 August 2nd 13 12:37 PM
LX7007FC Flight Recorder gains IGC-approval. Ian Strachan Soaring 0 January 24th 12 02:11 PM
New type of Flight Recorder gains IGC-approval Ian Strachan Soaring 0 August 31st 11 06:21 AM
New IGC-approval for GNSS Flight Recorder Ian Strachan Soaring 0 February 14th 09 08:00 PM
IGC-approval issued for Aircotec GPS Flight Recorder Ian Strachan Soaring 0 May 30th 06 11:47 PM
