Wing Frequency measuring app
Old March 6th 16, 01:58 PM posted to rec.aviation.soaring
Soarin Again[_2_]
Default Wing Frequency measuring app
At 02:42 06 March 2016, JS wrote:
Thanks, Clyde. I know that this measurement is done at every Form Two
inspection where you live.
Until this app, the device was a mark one eyeball, and counting "one,
two,
three, (etc) while looking at some cheap watch. Then doing it again
because
you're sure you lost count! The last bit probably won't change until you
believe the app can count.
On Saturday, March 5, 2016 at 6:01:24 PM UTC-8, IA DPE wrote:
In order for this to be recorded in the aircraft logbook, it would have
to be a FAA approved measuring device, right?
While I can see some value in knowing this reading, there would have to
be standardization in the measuring device and technique I would think.
20 years ago we could take a video (including a stop watch) at the wing tip
then play it back, in slow motion if preferred. Worked perfectly and it
didn't even require a computer.
Old March 6th 16, 03:55 PM posted to rec.aviation.soaring
Mark628CA
Clyde-
Handy little App. Thanks. One suggestion: Put a 10 or 15 second delay from the time the "Start" button is pressed before counting cycles. This will allow the frequency to stabilize before starting the count.
Also, a summary page would be cool. Test time, number of beats.
Definitely worth the $0.99.
Old March 6th 16, 05:11 PM posted to rec.aviation.soaring
son_of_flubber
Has anyone set up their glider, then measured L and R wingtips, say 10 repetitions from dead stop and looked at the results for consistency?
Can it ever be 'normal' for the L and R wingtips to yield different measurements? How much deviation in successive measurements is acceptable?
Does temperature of the glider affect the measurement?
Old March 7th 16, 02:24 AM posted to rec.aviation.soaring
On Monday, 7 March 2016 02:55:35 UTC+11, Mark628CA wrote:
Clyde-
Thanks for the suggestions; I don't think the delay is necessary since it only averages over the last 20 beats. I am going to change that to a time, rather than a number of beats, since that means a wing at 100 bpm takes twice as long as one at 200 to measure. So I think I'll change it to counting the last 10 seconds or so. It calculates the standard deviation of the beat interval and announces success when that is below .02 for the sample time.
I have some other optimisation ideas to improve the performance on gliders with very flexible wings, which sometimes have a second order vibration going on at the same time.
Clyde
Old March 6th 16, 10:03 PM posted to rec.aviation.soaring
On Saturday, 5 March 2016 08:39:05 UTC+11, wrote:
I have written an app that measures wing frequency - currently available for Android on the Play Store he https://play.google.com/store/apps/d...j.ios.wingfreq.
An IOS version will be available once I jump through the various hoops Apple places in the way.
Video of it in action he https://youtu.be/dBJOBxGWtCQ.
Clyde.
There is absolutely no difference in measured wing frequency whether done on a cradle or main / tail wheel skid or wheel. Try it out before you write otherwise. - Rolf
Rolf
Old March 6th 16, 11:15 PM posted to rec.aviation.soaring
jfitch
Clyde.
Rolf
So can I assume before you posted that you checked every glider in existence, on every cradle imaginable, and at every tire pressure?
On my Schleicher at least, the builder has called out some very specific jacking points for this procedure.
Old March 7th 16, 02:27 AM posted to rec.aviation.soaring
Rolf
I have tried it out - and have seen differences. One in particular was 135 on the wheel and 141 on the cradle. That's not a huge difference, but enough to warrant a closer look, so consistency in technique will help avoid false alarms.
Clyde
Old March 7th 16, 03:41 PM posted to rec.aviation.soaring
Eric Munk
At 07:23 07 March 2016, Steve Thompson wrote:
Suggest instead of opinion - just use the MM for the glider.
A very good suggestion. Did a Twin Astir wing frequency check the other
week, and that was off by 5 compared to the last measurements. Turns out it
somewhat unusually should sit on its wheel and skid (12th item of the
annual checklist in the mainenance manual) not on threstles, with a
specified tyre pressure of 2.5-2.8 bar. Remeasured and it now was bang on.
The way you measure DOES matter.
Old March 7th 16, 06:11 PM posted to rec.aviation.soaring
firsys
Clyde.
The easy and revealing part of the test, is to observe the wing tip
phase; in the first bending mode they should be synchronised within inches of each other. A wing lagging in phase would indicated spar or skin damage.
This is probably more accurate than the frequency test.
JMF
ASH26 wing frequency [email protected] Soaring 9 August 25th 13 03:27 AM
Measuring the effectiveness of a sandblaster? Michael Horowitz Home Built 17 June 14th 09 12:50 PM
measuring flap angles for rigging [email protected] Home Built 12 April 28th 06 02:46 PM
measuring arm distances Heino & Deanne Weisberg Home Built 1 October 21st 05 05:49 PM
Metric measuring tool source? DL152279546231 Home Built 12 April 29th 04 02:13 AM
