Wedekind Sleeve Source?
Old March 6th 16, 03:27 PM posted to rec.aviation.soaring
Default Wedekind Sleeve Source?
On Wednesday, March 2, 2016 at 7:06:17 PM UTC-5, ZP wrote:
Kevin, checking in to see if you ever installed them. This is still something I'm considering.
Thanks.
-Dirk
Not yet. I got the parts and looked over everything carefully, but my IA has been tied up working on a power plane that has been rode hard and put up wet.
In looking things over, I have decided to do the Wedikind Sleeves on the ailerons, and will do the Unreling on the dive brakes. The Ailerons are easier on the DG-400, they unscrew, where the dive brakes are riveted and GLUED, making it very difficult if not impossible to get them apart without damage.
I checked on the price of getting new push rods and Holellier, but is was going to be ridiculous.
I will have two Wedekind sleeves for sale that will fit the DG-400 after I get mine installed.
Kevin
Old March 7th 16, 07:04 AM posted to rec.aviation.soaring
Tango Whisky
Le dimanche 6 mars 2016 16:27:13 UTC+1, a écrit*:
Thanks.
-Dirk
The glue is Araldit. If you heat it up to around 100°C, it will come apart easily.
Old March 8th 16, 01:52 AM posted to rec.aviation.soaring
Thanks.
-Dirk
I went on their web site, but several glues. Any idea which one?
Also, is there any concern with changing temper on the aluminum push rods when heating?
Kevin
Old March 8th 16, 03:11 AM posted to rec.aviation.soaring
Paul Villinski
Kevin, I have the set-up you describe on my 400: Wedekind sleeves on ailerons, and the plastic sleeves on dive brakes. I got the safety sleeves from Pacific Aerosport. This works very well for me, and I wouldn't bother installing Wedekinds on the dive brakes.
Old March 8th 16, 12:57 PM posted to rec.aviation.soaring
Thanks Paul,
I was originally going to do them all, but as you know the dive brakes are more complicated, and I had decided to go the way you suggest.
I ordered the sleeves from DG direct and they were not packed well and destroyed upon arrival. They refunded me, and I will order from Pacific Aerosport now.
Thanks for the conformation on going this way.
Kevin
92
Old March 8th 16, 04:19 PM posted to rec.aviation.soaring
Jonathan St. Cloud
I thought WD-40 was kerosene and perfume. It is a not a very good lubricant, it is great at displacing water.
Old March 8th 16, 04:59 PM posted to rec.aviation.soaring
BobW
You gotta love the internet...source of all the world's answers, some of them
even correct.
Some years ago I heard an interview of the then CEO of the creating company of
WD-40. His version pretty much matched what you'll find at:
http://brokensecrets.com/2010/06/11/...ents-and-uses/
though he was more explicit when explaining that to "protect the Atlas missile
from corrosion" meant its many, external, electrical connectors. Basically, it
was intended originally to discourage (by displacement if necessary) water
from those entering into those connectors while the missiles sat on the
launching pad, often for extended periods of time. Sadly, he didn't comment on
the source of the wonderful (IMHO!) scent...
Having occasionally used it when messing with sailplanes, makes the above
information - worth every cent you paid for it - acceptable content for this
newsgroup.
Bob - auto-connecting since 1981 - W.
Old March 8th 16, 03:26 AM posted to rec.aviation.soaring
Thanks.
-Dirk
Kevin
If you're heating enough to change the temper, you're also cooking the glue and making really "not nice" colors/smells. Likely 100*C is short of changing the color of the paint (in short duration).
Best bet is to use a really good hobby heat gun, or a "middling" industrial heat gun.
No torches needed.......
Old March 8th 16, 10:04 AM posted to rec.aviation.soaring
Vernon Brown
Good advise from JJ, on one occasion when I had my Std Cirrus one control
connection jammed half way on a ball end when assembling, it would not go
fully on and it wouldn’t come off, may have been a foreign matter, dust
etc contaminating it, operating the control while applying pressure got it
off.
So I started to cleaned each ball end then lubricate with thin oil (WD40)
spray the oil on a finger then apply to the ball end before assembly, never
had any problem after that.
=E9crit=A0:
stil=
=20
Thanks.
-Dirk
=20
m=
and=
put up wet. =20
=20
on
ar=
and=
withou=
t damage.
=20
=20
The glue is Araldit. If you heat it up to around 100=B0C, it will
come
apart easily.
=20
=20
rods=
when heating?
=20
Kevin
glue=
chang=
industrial=
heat gun.
Old March 8th 16, 12:26 PM posted to rec.aviation.soaring
Tango Eight
Way off track, but may I drop a tip here?
Vernon: WD-40 is fish oil. It's a great water dispersant (the "WD" in WD-40), but it has lousy oxidation stability and gets gummy. Use Break Free CLP.
best,
Evan Ludeman
Wedekind sleeve Hartley Falbaum[_2_] Soaring 4 February 5th 14 12:54 PM
Wedekind sleeve for Std Cirrus John Galloway Soaring 8 July 9th 13 02:15 PM
pvc tubing/sleeve source? Jim Burns Owning 4 September 28th 06 03:36 AM
pvc tubing/sleeve source? Jim Burns Home Built 4 September 28th 06 03:36 AM
Source for Wedekind sleeves - AS-W20a Mark Grubb Soaring 7 April 6th 04 08:19 PM
