Vernon and 5Z,
The safety pins I was referring to look like this. http://aviation.derosaweb.net/wedeki.../safetypin.jpg. While mine were tied to something to prevent loosing them in the belly of the beast, they were a bear for me to install just by feel (at least for my level of dexterity). The safety pins that you show on your ASW-20's might be a different solution to the issue covered in the AD. http://ntl.bts.gov/lib/5000/5700/5722/ad97-08-06_r1.pdf. Never seen them before. Were they home made? From Schleicher? Someone else? Also, maybe the location of your fittings are more accessible in the 20. On the DG's two of the fittings are easy to get to (through a small white hole while looking into darkness against bright sunlight) while two of the fittings are totally buried, invisible, and are difficult to get to at the best of times. I raise a glass to my next ship that will have automatic hookups! My $0.02 - John |
![]() John, your links don’t work, cant see the photos. Vernon At 16:17 06 March 2016, Oscar-Hotel-Mike wrote: Vernon and 5Z, The safety pins I was referring to look like this. http://aviation.derosaw= eb.net/wedekind/documentation/safetypin.jpg. While mine were tied to somet= hing to prevent loosing them in the belly of the beast, they were a bear fo= r me to install just by feel (at least for my level of dexterity). =20 The safety pins that you show on your ASW-20's might be a different solutio= n to the issue covered in the AD. http://ntl.bts.gov/lib/5000/5700/5722/ad9= 7-08-06_r1.pdf. Never seen them before. Were they home made? From Schleic= her? Someone else? =20 Also, maybe the location of your fittings are more accessible in the 20. O= n the DG's two of the fittings are easy to get to (through a small white ho= le while looking into darkness against bright sunlight) while two of the fi= ttings are totally buried, invisible, and are difficult to get to at the be= st of times. I raise a glass to my next ship that will have automatic hookups! =20 My $0.02 - John=20 =20 |
On Sunday, March 6, 2016 at 12:30:08 PM UTC-5, Vernon Brown wrote:
John, your links don't work, cant see the photos. Vernon At 16:17 06 March 2016, Oscar-Hotel-Mike wrote: Vernon and 5Z, The safety pins I was referring to look like this. http://aviation.derosaw= eb.net/wedekind/documentation/safetypin.jpg. While mine were tied to somet= hing to prevent loosing them in the belly of the beast, they were a bear fo= r me to install just by feel (at least for my level of dexterity). =20 The safety pins that you show on your ASW-20's might be a different solutio= n to the issue covered in the AD. http://ntl.bts.gov/lib/5000/5700/5722/ad9= 7-08-06_r1.pdf. Never seen them before. Were they home made? From Schleic= her? Someone else? =20 Also, maybe the location of your fittings are more accessible in the 20. O= n the DG's two of the fittings are easy to get to (through a small white ho= le while looking into darkness against bright sunlight) while two of the fi= ttings are totally buried, invisible, and are difficult to get to at the be= st of times. I raise a glass to my next ship that will have automatic hookups! =20 My $0.02 - John=20 =20 They both just worked for me. Older Windows & Chrome browser. |
This looks like what I used:
http://www.mcmaster.com/#90174a112/=11fc3wv 5Z On Sunday, March 6, 2016 at 8:17:42 AM UTC-8, Oscar-Hotel-Mike wrote: Vernon and 5Z, The safety pins I was referring to look like this. http://aviation.derosaweb.net/wedeki.../safetypin.jpg. While mine were tied to something to prevent loosing them in the belly of the beast, they were a bear for me to install just by feel (at least for my level of dexterity). The safety pins that you show on your ASW-20's might be a different solution to the issue covered in the AD. http://ntl.bts.gov/lib/5000/5700/5722/ad97-08-06_r1.pdf. Never seen them before. Were they home made? From Schleicher? Someone else? Also, maybe the location of your fittings are more accessible in the 20. On the DG's two of the fittings are easy to get to (through a small white hole while looking into darkness against bright sunlight) while two of the fittings are totally buried, invisible, and are difficult to get to at the best of times. I raise a glass to my next ship that will have automatic hookups! My $0.02 - John |
Wedekind sleeve | Hartley Falbaum[_2_] | Soaring | 4 | February 5th 14 12:54 PM |
Wedekind sleeve for Std Cirrus | John Galloway | Soaring | 8 | July 9th 13 02:15 PM |
pvc tubing/sleeve source? | Jim Burns | Owning | 4 | September 28th 06 03:36 AM |
pvc tubing/sleeve source? | Jim Burns | Home Built | 4 | September 28th 06 03:36 AM |
Source for Wedekind sleeves - AS-W20a | Mark Grubb | Soaring | 7 | April 6th 04 08:19 PM |
