Wedekind Sleeve Source?
Old March 8th 16, 01:50 PM posted to rec.aviation.soaring
Vernon Brown
Default Wedekind Sleeve Source?
At 12:26 08 March 2016, Tango Eight wrote:
On Tuesday, March 8, 2016 at 5:17:58 AM UTC-5, Vernon Brown wrote:
So I started to cleaned each ball end then lubricate with thin oil
(WD40)
Way off track, but may I drop a tip here?
Vernon: WD-40 is fish oil. It's a great water dispersant (the "WD" in
WD-40), but it has lousy oxidation stability and gets gummy. Use Break
Free CLP.
best,
Evan Ludeman
Thanks Evan, didn’t know WD40 was fish oil,
gumming up should not a problem if controls are cleaned before every
rigging, which I did, but useful info nerveless, which will be useful to
others.
Sold my Cirrus about 12 years ago, had an LS8/18 for a while, now I have an
LS6c 17.5 both auto connects.
Vernon
Old March 8th 16, 02:29 PM posted to rec.aviation.soaring
Giaco
(WD40)
Free CLP.
best,
Evan Ludeman
Thanks Evan, didn't know WD40 was fish oil,
others.
Vernon
I've always had great luck with Marvel Mystery Oil. It was the club solution for just about all spring lubing at CCSC and worked great even at super cold wave temps. FWIW
Old March 8th 16, 12:01 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
On Mon, 07 Mar 2016 17:52:54 -0800, kevinsoar wrote:
I went on their web site, but several glues. Any idea which one?
Disclaimer: the following is model aircraft buildig and general use
experience, not direct aviation use, so please bear that in mind. Also I
think the formulation may have changed a bit recently, since the
'standard' Araldite used to be yellowish when mixed and is now milky
white.
There are two common Araldite types.
- "Standard", which used to be known as '24 hour' Araldite comes in blue/
white coloured tubes, takes about 24 hours to fully cure at room temp,
and gives a really tough joint. It tends to soften if you heat it after
its cured. So much so, that if you know its going to be used at a higher
temp, you should let it cure at the expected use temp or a bit hotter.
This is the one I use for general engineering and anywhere I expect the
joint to be load bearing.
- "Rapid" comes in red/white tubes, is handlable after 30 mins and full
strength after 1-2 hours. I've never heated this after curing so have no
idea whether it heat softens because I normally use it for gluing wood
and plastic. Its sets hard rather than tough: the glue shatters if
overstressed. I only use it for low stress joints and/or for quick
repairs where speed of cure is more important than glue strength.
Bottom line: anywhere that you care about joint integrity, use Araldite
Standard in the blue/white tube set.
Also, is there any concern with changing temper on the aluminum push
rods when heating?
As others have said, if you heat Araldite epoxies hot enough for long
enough to affect the temper of metal its joining stuff, the epoxy bond
will be destroyed rather than softened. And, like them, I'd use a hobby-
style (900w) heat gun to soften an existing epoxy joint.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Wedekind sleeve Hartley Falbaum[_2_] Soaring 4 February 5th 14 12:54 PM
Wedekind sleeve for Std Cirrus John Galloway Soaring 8 July 9th 13 02:15 PM
pvc tubing/sleeve source? Jim Burns Owning 4 September 28th 06 03:36 AM
pvc tubing/sleeve source? Jim Burns Home Built 4 September 28th 06 03:36 AM
Source for Wedekind sleeves - AS-W20a Mark Grubb Soaring 7 April 6th 04 08:19 PM
