Wedekind Sleeve Source?
Old March 8th 16, 03:26 AM posted to rec.aviation.soaring
Default Wedekind Sleeve Source?
On Monday, March 7, 2016 at 8:52:57 PM UTC-5, wrote:
On Monday, March 7, 2016 at 2:04:59 AM UTC-5, Tango Whisky wrote:
Le dimanche 6 mars 2016 16:27:13 UTC+1, a écrit*:
On Wednesday, March 2, 2016 at 7:06:17 PM UTC-5, ZP wrote:
Kevin, checking in to see if you ever installed them. This is still something I'm considering.
Thanks.
-Dirk
Not yet. I got the parts and looked over everything carefully, but my IA has been tied up working on a power plane that has been rode hard and put up wet.
In looking things over, I have decided to do the Wedikind Sleeves on the ailerons, and will do the Unreling on the dive brakes. The Ailerons are easier on the DG-400, they unscrew, where the dive brakes are riveted and GLUED, making it very difficult if not impossible to get them apart without damage.
The glue is Araldit. If you heat it up to around 100°C, it will come apart easily.
I went on their web site, but several glues. Any idea which one?
Also, is there any concern with changing temper on the aluminum push rods when heating?
Kevin
If you're heating enough to change the temper, you're also cooking the glue and making really "not nice" colors/smells. Likely 100*C is short of changing the color of the paint (in short duration).
Best bet is to use a really good hobby heat gun, or a "middling" industrial heat gun.
No torches needed.......
Old March 8th 16, 10:04 AM posted to rec.aviation.soaring
Vernon Brown
Good advise from JJ, on one occasion when I had my Std Cirrus one control
connection jammed half way on a ball end when assembling, it would not go
fully on and it wouldn’t come off, may have been a foreign matter, dust
etc contaminating it, operating the control while applying pressure got it
off.
So I started to cleaned each ball end then lubricate with thin oil (WD40)
spray the oil on a finger then apply to the ball end before assembly, never
had any problem after that.
=E9crit=A0:
stil=
=20
Thanks.
-Dirk
=20
m=
and=
put up wet. =20
=20
on
ar=
and=
withou=
t damage.
=20
=20
The glue is Araldit. If you heat it up to around 100=B0C, it will
come
apart easily.
=20
=20
rods=
when heating?
=20
Kevin
glue=
chang=
industrial=
heat gun.
Old March 8th 16, 12:26 PM posted to rec.aviation.soaring
Tango Eight
Way off track, but may I drop a tip here?
Vernon: WD-40 is fish oil. It's a great water dispersant (the "WD" in WD-40), but it has lousy oxidation stability and gets gummy. Use Break Free CLP.
best,
Evan Ludeman
Old March 8th 16, 01:50 PM posted to rec.aviation.soaring
Vernon Brown
(WD40)
Free CLP.
best,
Evan Ludeman
Thanks Evan, didn’t know WD40 was fish oil,
gumming up should not a problem if controls are cleaned before every
rigging, which I did, but useful info nerveless, which will be useful to
others.
Sold my Cirrus about 12 years ago, had an LS8/18 for a while, now I have an
LS6c 17.5 both auto connects.
Vernon
Old March 8th 16, 02:29 PM posted to rec.aviation.soaring
Giaco
(WD40)
Free CLP.
best,
Evan Ludeman
Thanks Evan, didn't know WD40 was fish oil,
others.
Vernon
I've always had great luck with Marvel Mystery Oil. It was the club solution for just about all spring lubing at CCSC and worked great even at super cold wave temps. FWIW
Wedekind sleeve Hartley Falbaum[_2_] Soaring 4 February 5th 14 12:54 PM
Wedekind sleeve for Std Cirrus John Galloway Soaring 8 July 9th 13 02:15 PM
pvc tubing/sleeve source? Jim Burns Owning 4 September 28th 06 03:36 AM
pvc tubing/sleeve source? Jim Burns Home Built 4 September 28th 06 03:36 AM
Source for Wedekind sleeves - AS-W20a Mark Grubb Soaring 7 April 6th 04 08:19 PM
