TOPMETEO support ??
Old March 9th 16, 02:58 AM posted to rec.aviation.soaring
son_of_flubber
Default TOPMETEO support ??
Does Top Meteo require Java?
I can display an interesting chart for the USA Region, but I see no controls for zooming. I'm on a Chromebook which does not support Java.
Old March 9th 16, 06:32 PM posted to rec.aviation.soaring
WaltWX[_2_]
Does not require a Java plugin
Walt Rogers WX
Old March 9th 16, 06:37 PM posted to rec.aviation.soaring
WaltWX[_2_]
TopMeteo charts are selectable by regions including entire U.S. CONUS and are not zoomable.
It takes a little time to browse around and get used to the the UI. Under the charts section one can animate all the hours, stop start... and easily select other charts or one of the six forecast days. Make sure you spend some time configuring your own "My Stations" in order to see tables of hourly parameters for any point.
Very different UI than we've been accustomed to with XCSkies or DrJack.
Lots of information there just accessible in a different way.
Walt Rogers WX
TopMeteo Soaring Weather Now Available for United States Region WaltWX[_2_] Soaring 18 April 30th 16 10:16 PM
Bushite soldiers beat to death innocent Children to 'let offsteam' - Support Our Demands For Open Communications - Unraveling the Mystery- you can not find a single soldier on Earth to publicly support GeorgeW Bush without immediately being re Tiger Naval Aviation 0 April 10th 08 01:20 AM
LS support through DG Rick Lewis Soaring 5 September 24th 04 05:09 PM
thanks for the support tony zambon Piloting 6 August 19th 03 03:04 AM
Support for SN-10 cernauta Soaring 3 July 29th 03 01:12 AM
