On Monday, March 14, 2016 at 9:14:18 PM UTC-4, wrote:
On Monday, March 14, 2016 at 4:01:21 PM UTC-7, wrote: I have a new CN2 and I've loaded a (what I believe) is a carefully formatted .stx file. Tab delimited. Most of the waypoints show the correct positive field elevation. A few (seemingly random points) show a negative number. Specifically -3277.55916. The altitude in the file is 320. The column header is Elevation[Feet]. Anyone else experienced this and if so, know what the cure is? Thanks, Mark Can we PLEASE get away from windows programs? Maybe, in 50+ years. Notepad/wordpad have been around sorta since "the dawn of the PC" (think DOS stuff..... very basic PC stuff). They work and MS has not FUBARED them as far as I can see. Now, you want to talk about some MS OS's, that is a totally different discussion. What would you propose? Keep in mind, it has to work with the software you're using, notepad/wordpad work with pretty much EVERY MS OS. |
Please note that "Notepad++" is not the same as "Notepad".
"Noteped++" is a free piece of software that is not affiliated with Microsoft, and is way better for many situations (especially for programmers and other technical work; although it's just fine for casual users as well). You can download versions of Notepad++ for several different OSes, including both Windows and Mac. --Noel |
thanks Noel
When editing or creating your own waypoint files (regardless of format) a good practice is to use a known good waypoint file as a template to start from. You can learn more about the STX format here http://soaringweb.org/TP/stx.html However, DON'T USE THE EXAMPLES on that page to create your own files. They won't work. As a colleague puts it "The good thing about STX is it's nice and flexible. The bad thing about STX is it's nice and flexible." The examples just warned against illustrate this flexibility nicely but will cause problems in your flight computer. Please use instead a waypoint database intended for ClearNav chosen from one of the many world wide soaring sites on the WWTPE. best regards, Evan Ludeman for CNi |
FlarmNet file format - ClearNav? | thermals1 | Soaring | 1 | July 6th 15 11:17 PM |
Old XCSoar DAT file format | bds | Soaring | 7 | March 31st 15 05:41 PM |
Hangar Queen in PPS format large file 3.21 MB | Bruce R | Aviation Photos | 1 | March 15th 07 02:49 AM |
MEA oddity near Harrisburg, PA? | Journeyman | Instrument Flight Rules | 14 | May 16th 06 03:42 PM |
Weather chart oddity? | Dylan Smith | Piloting | 8 | April 21st 06 04:47 PM |
