Shameless update from Dale Kramer
Old March 16th 16, 08:58 PM posted to rec.aviation.soaring
Steve Koerner
Default Shameless update from Dale Kramer
On Wednesday, March 16, 2016 at 1:12:18 PM UTC-7, DaleKramer wrote:
Hi Steve,
The transitions should be very quick. Thrust to weight will be about 1.3/1 so acceleration into cruise should be very quick. Landing transitions will basically be just a normal final approach to a touchdown spot but with the idea of being 50 ft high (or so) when you get there. This transition will be very easy to verify and demonstrate with the 1/4 scale. Can always add a few more pounds of battery if needed.
I am hoping to design the gear such that a single person can tip it from tail to nosegear if it gets windy for a tiedown.
What will be strange is that the 'ideal' landing direction will be a 90 degree crosswind landing wrt wind efects.
Great comments!
I saw that for Nephi, hope it continues for a while. Can't afford a glider yet.
Thanks,
Dale
It will be interesting to see how that vertical landing works out with the model. I can't visualize how a normal approach speed can get you to a vertical position. Without thrust vector control it seems like it would require a high approach speed in order to then pull up to a vertical position and begin backing.
Have you modeled the vertical landing? How high does the aircraft get if things are done correctly? What speed does it back down at? Will the landing be autonomous or pilot controlled?
I can swallow the idea of vertical take-off much more readily than the landing. Maybe I'm just not visualizing the dynamics of the landing problem correctly.
Old March 16th 16, 09:58 PM posted to rec.aviation.soaring
Steve Koerner
Thinking about that some more, you don't necessarily have to approach at a higher speed and pull up. With enough thrust you can power your way through deep stall. Yet I still think it questionable that you can have enough battery life to assuredly get landed before it all comes to an end. I hope it works.
Old March 17th 16, 02:33 AM posted to rec.aviation.soaring
DaleKramer
Steve,
Sorry, been busy, but yes you got it. With top electrics OFF and bottom electrics ON FULL, and wingtip electrics on 1/2 and Rotax on FULL there is still 1:1 thrust and about 900 ft-lbs of thrust pitch UP moment available (plus aerodynamic pitch up from elevators). It should pitch up to hover relatively easily. There are two throttles for manual flight, one for electric and one for Rotax. Yes there will be a auto transition mode. Electrics don't even come on until slow speed (fixed pitch props). Multirotors come down very quickly and very stable with a good controller, not like the limitations of the 1950's tail sitters (all manual control).
Glad you are thinking about it
Dale
Old March 17th 16, 06:35 AM posted to rec.aviation.soaring
bumper[_4_]
"Multirotors come down very quickly and very stable with a good controller, not like the limitations of the 1950's tail sitters (all manual control)."
Vortex ring state can occur when settling under power with helicopters as the rotor settles into its own downwash. This has caused a number of crashes including the V-22 Osprey. So there is risk in "coming down very quickly". Once this occurs in helicopters (and I've only personally hovered models and real ones in forward flight :c) adding power simply feeds into the vortex problem. The save is to apply cyclic and move off into clean air. Is that an option with a tail sitter? Is there a "save"?
Another question is that once pitched up to land, would Rotax failure have a recovery mode?
Old March 17th 16, 11:17 AM posted to rec.aviation.soaring
DaleKramer
Oops, that is 900 ftlbs in static conditions. It would be much less at any significant transition speed but still, I think the transition can be done without much of a zoom up. There have been all electric and 'similar aerodynamics' transition models built before and the videos I have seen of their transitions did not show much of a pull up but of course each design is different.
Bumper, yes vortex ring state conditions are possible. I believe that that risk can be reduced by adding some forward translation when you let down and by staying away from other vlift vehicles. Once near the ground of course you need to slow all movement down.
These conditions we are talking about the need for testing, just highlight why I am building a 1/4 scale model right now, not the full scale.
Didn't the Osprey put some sort of restriction on landing in close proximity to other Ospreys as an acceptable risk reduction for this issue?
Interesting to note that this condition only became apparent, years into the multi billion (I think billion) dollar program. Glad we all can take advantage of their experience.
Rotax failure results in the need for airbags if you are in transition or hover. Since all these failure we are talking about are for hover or neaar hover conditions, they would all happen close to the ground where the likelihood of a whole vehicle 'parachute' letdown or ejection seat failure would be very high. Having survived a very high rate of descent sailplane accident, where trouble began at a very altitude, I can say that, at least in my case, I believe that cockpit air bags would have greatly reduced my injuries.
For the past few years I have toyed, as many others have, with the idea of manned 'multirotor' designs. The keys to having a design with 'acceptable risk' failure modes is spending most of the flight time in aerodynamic flight, using more than 3 or 4 rotors for hover, redundant motor controllers and hover controllers (yet to be worked out) and airbags I also considered just doing transitions over water (it is softer with a landing pad of waters edge, which is funny at first but may be a good practice for risk reduction whenever possible.
Old March 17th 16, 11:21 AM posted to rec.aviation.soaring
DaleKramer
Edit 'when trouble vegan at a very LOW altitude'
Old March 17th 16, 11:30 AM posted to rec.aviation.soaring
DaleKramer
Edit 'when trouble began at a very LOW altitude' and 'landing pad AT waters edge'
and a few other typos, oh well!
Old March 17th 16, 02:11 PM posted to rec.aviation.soaring
WB
Borrow a foam pit from the extreme sports folks.
Old March 17th 16, 03:05 PM posted to rec.aviation.soaring
Paul Agnew
Vortex ring state has nothing to do with "staying away from other vlift vehicles." VRS is the interaction with your own vortex that decreases the relative angle of attack on your own airfoils/rotor blades. The recovery is to lower collective (altitude permitting) and use cyclic to pitch forward in order to fly out of the ring state - essentially to leave the vortex behind you. Simple adding power will exacerbate the "settling with power" and accelerate your descent.
I've encountered settling with power a couple of times back when I flew helicopters. The worst was when holding a stationary position at 1000' in a Bell 47 with a skysign (grid of lights). The bottom suddenly dropped out and the entire ship started shuddering as the blades went in an out of a stalled or zero lift state. Recovery was textbook and we lost about 200' feet.
How to recover in something like this proposed VTOL will be a large hurdle to surmount for certification and for overall safety of the design.
Paul A.
(Knocking the dust off my CFI-Rotorcraft...)
Jupiter, FL
Art Kramer Andrew Chaplin Military Aviation 8 July 12th 04 11:25 PM
Art Kramer, your computer may be infected old hoodoo Military Aviation 6 May 24th 04 12:43 PM
Question for Art Kramer. M. H. Greaves Military Aviation 2 May 10th 04 05:17 PM
More B-26 Nonsense from Art Kramer funkraum Military Aviation 7 January 21st 04 10:53 PM
ATTN: Art Kramer robert arndt Military Aviation 2 July 4th 03 02:33 PM
