Shameless update from Dale Kramer
Old March 17th 16, 04:41 PM posted to rec.aviation.soaring
DaleKramer
Default Shameless update from Dale Kramer
Jim, that is correct, in the full scale vLazair there is an onboard 15kw generator, powered by a separate gas motor, that charges the batteries in flight. Should never need to charge batteries from the power grid and it will only take about 15 minutes in flight to charge the last landing and last takeoff. The generator is just a JM1 motor attached to a gas motor and its 3 phase output rectified. Generator runs at governed rpm which sets charge voltage. Very light setup.
Dale
Old March 17th 16, 04:53 PM posted to rec.aviation.soaring
DaleKramer
Holding a steady voltage with a Rotax installed generator is more complex, besides, I want the generator on board when I remove the wings and Rotax so that I can drive the remaining 'motorcycle' around on the road.
Dale
Old March 17th 16, 05:22 PM posted to rec.aviation.soaring
LOL I like that Dale
Old March 17th 16, 05:23 PM posted to rec.aviation.soaring
Craig Funston
Dale
Dale, the JM1 + gas motor and some batteries sounds like a good hybrid option for a FES setup. What's the weight and output on the charging unit?
Old March 17th 16, 05:38 PM posted to rec.aviation.soaring
DaleKramer
Is that Flywheel Energy Storage or Flat Earth Society?
I haven't found the gas motor I want yet for the 15kw output but I have lots of choices in the 8-10kw. Since this is needed much farther down the road, I have not put much detail design into it. I think I can build this for 25-30lbs. The JM1 only weighs 6 lbs. 10kw may be fine for me since who cares much if it takes 22 minutes to charge up during cruise versus 15 minutes.
Old March 17th 16, 05:40 PM posted to rec.aviation.soaring
DaleKramer
Battery weight, you pick.
Old March 17th 16, 06:09 PM posted to rec.aviation.soaring
DaleKramer
We have JM1's wound at 115 kv (I think that is RMS) but you can have change that on ordering.
Old March 17th 16, 08:03 PM posted to rec.aviation.soaring
Craig Funston
Dale, that would be the electric glider that goes into regeneration mode when you're in thermals. Take that booming 10 knotter and dial in the regen until you can't climb. Hang in there until you've extracted the energy you want so you can skip all those wimpy thermals in between the good ones. We used to call that L/D ;-) Somewhere i came across a very technical paper on this, but haven't checked the numbers. The catch is always in underestimating the losses and overestimating the efficiency.
Hybrid glider might end up working, but what a bummer to have a gasoline motor running constantly at low output to charge batteries.
Old March 17th 16, 09:03 PM posted to rec.aviation.soaring
DaleKramer
Regeneration in thermals used to be high on my list of things to try but now I just do not see being able to get much efficiency out of the process. Traction props just aren't very efficient at being a windmill blade.
Old March 17th 16, 09:13 PM posted to rec.aviation.soaring
DaleKramer
Paul,
None of the rotors are directly in the propwash cone of the others, so I do not see any direct interaction between them causing a blanketing effect that reduces AOA of other other rotors.
Thanks for the comments, all welcome.
Dale
Art Kramer Andrew Chaplin Military Aviation 8 July 12th 04 11:25 PM
Art Kramer, your computer may be infected old hoodoo Military Aviation 6 May 24th 04 12:43 PM
Question for Art Kramer. M. H. Greaves Military Aviation 2 May 10th 04 05:17 PM
More B-26 Nonsense from Art Kramer funkraum Military Aviation 7 January 21st 04 10:53 PM
ATTN: Art Kramer robert arndt Military Aviation 2 July 4th 03 02:33 PM
