Shameless update from Dale Kramer
Old March 21st 16, 03:02 AM posted to rec.aviation.soaring
Andy Blackburn[_3_]
Default Shameless update from Dale Kramer
The blowing was to use the blown air to create the trailing edge if the airfoil so you could have a rotor where the clockwise edge was trailing when the rotor was spinning and then when you stop the rotor to fly the blades as wings half the blades blow out if the counter-clockwise newly trailing edge. Without this, you'd have half the rotor ballades trying to fly backwards when you convert them to fixed wings. It's a crazy idea that blowing through a slot on the lower aft edge of a blunt shape creates a trailing edge streamlined effective shape.
  #92
Old March 21st 16, 03:24 AM posted to rec.aviation.soaring
DaleKramer
Interesting, could they make it like a down flap shape if they blew harder?
  #93
Old March 21st 16, 04:26 AM posted to rec.aviation.soaring
Andy Blackburn[_3_]
There's a joke in there somewhere...
  #94
Old March 21st 16, 11:14 AM posted to rec.aviation.soaring
DaleKramer
Actually I am just speculating that, depending on the blowhole angle on the lower 'TE', they might be able to affect the camber of the airfoil if the blew harder, or would that just mess up the 'phantom' airfoil profile.
  #95
Old March 21st 16, 03:07 PM posted to rec.aviation.soaring
Andy Blackburn[_3_]
I would guess that you could get some tailoring by changing pressure, but the Coanda effect really counts on boundary layer attachment and then separation to do its thing, so there are almost certainly limits. Turns out the RSRA never flew through a transition so the excitement around the hangar was speculative. Some helpful reference material on the technology.
http://www.sikorskyarchives.com/X-WING.php
https://en.m.wikipedia.org/wiki/Blown_flap
Also, some NASA concepts for personal electric VTOL:
http://ntrs.nasa.gov/archive/nasa/ca...0110011311.pdf
https://m.youtube.com/watch?v=I_KloqLa2Og
  #96
Old March 21st 16, 04:07 PM posted to rec.aviation.soaring
Jonathan St. Cloud
And of course even further off subject, the MD NOTAR helicopters use the Coanda effect for the anti-torque. Works beautifully in over 2,000 holding the tick of an MD520.
  #97
Old March 21st 16, 04:25 PM posted to rec.aviation.soaring
DaleKramer
Great links, hadn't seen that good of a Puffin desription before or the X wing archive.
  #98
Old March 21st 16, 09:41 PM posted to rec.aviation.soaring
Steve Koerner
On Sunday, March 20, 2016 at 1:05:18 PM UTC-7, DaleKramer wrote:
Agreed, right now I am sort of allocating 1 minute WOT electric time with about 3 minutes of reserve (even though hovering should require about 1/2 power in electrics). This is another fine tunable value when the full size vLazair is detail designed. I am hoping that I can make vertical landings that use around 30 seconds of electric time.
I suppose if you can incorporate a very accurate indicator of remaining battery life with an alarm feature, or a separate reserve battery that is switched in when the main gets low, then that might work. I can't help but visualize myself spending several minutes trying to get her lined up to the helicopter pad on my future yacht. The seas are bumpy and the breeze variable -- I think the process might take a few minutes to get landed.
If Andy flies production unit number 1 and lives, and if there are positive reviews on Amazon, I will order unit number 7.
  #99
Old March 22nd 16, 12:22 AM posted to rec.aviation.soaring
DaleKramer
I am with you but at this point I am trying to be realistic in my empty weight predictions. I will increase battery capacity, down the road, if I can. I am really trying to build with existing technology that is available. At this stage I have a perfect 25 lbish pack in mind, by the time I build the full scale we will likely have 300+ whr/kg packs available.
Lucky #7, but Amazon reviews, I really question
  #100
Old March 22nd 16, 11:02 AM posted to rec.aviation.soaring
DaleKramer
Looks like this is the kind of project that gets funded nowadays on Kickstarter, the world will be such a better place
https://www.kickstarter.com/projects...?ref=discovery
Art Kramer Andrew Chaplin Military Aviation 8 July 12th 04 11:25 PM
Art Kramer, your computer may be infected old hoodoo Military Aviation 6 May 24th 04 12:43 PM
Question for Art Kramer. M. H. Greaves Military Aviation 2 May 10th 04 05:17 PM
More B-26 Nonsense from Art Kramer funkraum Military Aviation 7 January 21st 04 10:53 PM
ATTN: Art Kramer robert arndt Military Aviation 2 July 4th 03 02:33 PM
