Shameless update from Dale Kramer
Old March 22nd 16, 11:02 AM posted to rec.aviation.soaring
DaleKramer
Default Shameless update from Dale Kramer
Looks like this is the kind of project that gets funded nowadays on Kickstarter, the world will be such a better place
https://www.kickstarter.com/projects...?ref=discovery
Old March 23rd 16, 03:20 AM posted to rec.aviation.soaring
2G
I will apologize for using the word "stinking" - I will let your attitude speak for itself.
That said, this design is problematic. For example, you list the battery weight at 25 lb. I calculate that you will need about 100 lbs of battery (batteries cannot be discharged 100% and expect any decent lifetime). And that ONLY allows by your statement, 3-4 min of hovering. This is totally inadequate for any landing I would dare attempt. This means you will need MUCH more battery capacity than you allowed for, but I will stick to this time for the rest of the analysis.
Using freely available references, I calculated the ideal power to hover at sea level (not climb, mind you) at 131 hp with a MTOW of 1175 lb. Using a 0.75 FOM this increases to 175 hp. At a 10,000 ft density altitude this becomes 158 and 211 hp, respectively. Clearly your design is severely under powered. It gets worse when you want to climb and be able to transition from hovering to forward flight, when some of the electric motors will have to be shut down. These same references state that VTOL aircraft have a horsepower loading of less than 2: you are more than double this.
I am not confused about fore and aft. The pilot is faced forward in forward flight; his position must change to an aft facing position AND rotate 90 degrees. That amounts to 2 rotations on 2 axes of 90 and 180 degrees. When, exactly does this occur, while travelling forward in level flight or while hovering? I would assume hovering because of the extreme air blast and speed brake effect. While hovering the pilot WILL be exposed to the full thrust of the main motor. The thought of attempting such a maneuver scares the hell out of me! The potential of vertigo is not just huge - it is virtually certain. Another point that went unanswered.
Andy makes excellent points about the counter-rotation and stability issues.. As currently envisioned, the main motor cannot be operated at full power because the electric motors would not stabilize its torque. This problem is exacerbated when the aircraft tries to transition to horizontal flight when half the electric motors would have to be shut down. Combine an electric motor failure and you have a real problem. Notice that Dale never answered my question about thrust vectoring.
Fly by wire? You have just become a million dollar aircraft! This is completely unrealistic. You REALLY need to consult with engineers who have ACTUALLY designed fly by wire aircraft.
Qualifications are not important? Since the hell when? Building conventional aircraft from who knows what designs is NOT a representation of qualifications. I am approaching this whole project from the viewpoint of an unsophisticated investor; I don't particularly care what Dale does with his own money. BTW, there WERE NO aeronautical engineering schools at the time of the Wright Brothers; they invented it (they also used their OWN money!)
Old March 23rd 16, 06:07 AM posted to rec.aviation.soaring
Steve Koerner
So 2G,
Does this mean that if Dale builds a model and successfully flies off vertically, transitions to horizontal and lands it vertical, then you will eat the molds that the plane was made from?
Or are you saying that you will only eat the molds if he changes nothing from concept to completion?
Old March 24th 16, 12:46 AM posted to rec.aviation.soaring
2G
On Tuesday, March 22, 2016 at 11:07:23 PM UTC-7, Steve Koerner wrote:
So 2G,
Are you saying that the experts in the industry like J. Gordon Leishman don't know what they are talking about?
I would be more concerned that Dale builds a full-scale plane and attempts to fly it. All model planes I have seen have grossly higher power-weight ratios than their full-size counterparts.
Art Kramer Andrew Chaplin Military Aviation 8 July 12th 04 11:25 PM
Art Kramer, your computer may be infected old hoodoo Military Aviation 6 May 24th 04 12:43 PM
Question for Art Kramer. M. H. Greaves Military Aviation 2 May 10th 04 05:17 PM
More B-26 Nonsense from Art Kramer funkraum Military Aviation 7 January 21st 04 10:53 PM
ATTN: Art Kramer robert arndt Military Aviation 2 July 4th 03 02:33 PM
