i really mean spanwise, when i worked at schempp-hirth 6 years ago they always sanded spanwise for finish sanding. and i have been doing it that way at a nationally known glider refinishing company for 12 years.
On Thursday, March 24, 2016 at 5:30:06 PM UTC-4, Michael Opitz wrote: i take sections of wing and draw a line with pencil from leading edge to tr= ailing edge every 18 inches or so. then, with 800 (you can use 600) you'll = sand two sections at a time using spanwise strokes, working from leading ed= ge to trailing edge. Did you really mean spanwise and not chordwise??? When I worked at S-H, we NEVER sanded spanwise. It was either chordwise or alternating 45 degrees off chordwise. FWIW...... |
Dry vs. wet sanding | [email protected] | Soaring | 16 | February 19th 16 11:28 AM |
Gel coat removal - water sanding vs. straight line sanding | LS3 Pilot | Soaring | 45 | February 15th 10 03:32 PM |
Advice on sanding fibreglass | [email protected] | Home Built | 12 | April 28th 05 10:39 PM |
Sanding composites | [email protected] | Home Built | 12 | January 31st 05 06:47 AM |
Fear of Sanding | Stuart Grant | Soaring | 7 | January 17th 05 05:28 PM |
