Gelcoat Sanding
Old March 28th 16, 01:47 PM posted to rec.aviation.soaring
ND
Default Gelcoat Sanding
On Thursday, March 24, 2016 at 9:49:47 PM UTC-4, Mark628CA wrote:
but soapy residue also corrodes metal faster. so if oyu use any soap (we never do) make sure you take steps to protect your contol linkages, and hanges.
Another hint: Add a bit of dishwashing soap to the water you use to clean off your wet sanding paper and rinse the wing surface. It reduces the amount of residue that builds up on the sandpaper and makes it last longer.
And remember: Patience is a virtue. Take your time. And then take some more time. Good things come to those who exhibit patience.
At least with things like this. Other things require more immediate results. That's why high explosives were invented. Mining would take a LONG time if you had to use sandpaper.
Dry vs. wet sanding [email protected] Soaring 16 February 19th 16 11:28 AM
Gel coat removal - water sanding vs. straight line sanding LS3 Pilot Soaring 45 February 15th 10 03:32 PM
Advice on sanding fibreglass [email protected] Home Built 12 April 28th 05 10:39 PM
Sanding composites [email protected] Home Built 12 January 31st 05 06:47 AM
Fear of Sanding Stuart Grant Soaring 7 January 17th 05 05:28 PM
