Gelcoat Sanding
Old March 28th 16, 07:14 PM posted to rec.aviation.soaring
ND
Default Gelcoat Sanding
On Monday, March 28, 2016 at 12:20:45 PM UTC-4, Charlie M. (UH & 002 o
exactomundo.
On Monday, March 28, 2016 at 12:08:22 PM UTC-4, Ramy wrote:
I often hear that sanding is only a temporary solution, and after couple of years the gel coat will lift again and now you have a thinner gel coat layer and wider cracks. If so, why sanding unless you try to sell your glider?
Ramy
So you can save up for a full refinish. A "flattening sanding" helps with the aerodynamics followed by a good wax/polish can extend the life of what you have. A full refinish is not cheap.
Dry vs. wet sanding [email protected] Soaring 16 February 19th 16 11:28 AM
Gel coat removal - water sanding vs. straight line sanding LS3 Pilot Soaring 45 February 15th 10 03:32 PM
Advice on sanding fibreglass [email protected] Home Built 12 April 28th 05 10:39 PM
Sanding composites [email protected] Home Built 12 January 31st 05 06:47 AM
Fear of Sanding Stuart Grant Soaring 7 January 17th 05 05:28 PM
