On Monday, April 11, 2016 at 12:26:20 PM UTC-7, C-FFKQ (42) wrote:
On Monday, 11 April 2016 15:11:19 UTC-4, xcnick wrote: Nick, I'm sad to inform you that Udo died a few years ago after a lengthy illness. That is sad. In the Johnson article he works very hard to get to published L/D. However what struck me is how far off the manual's numbers are at the high end and he doesn't mention it. Are many manufactures too optimistic at the fast end? |
On Thursday, April 14, 2016 at 12:19:25 AM UTC-5, xcnick wrote:
On Monday, April 11, 2016 at 12:26:20 PM UTC-7, C-FFKQ (42) wrote: On Monday, 11 April 2016 15:11:19 UTC-4, xcnick wrote: Nick, I'm sad to inform you that Udo died a few years ago after a lengthy illness. That is sad. In the Johnson article he works very hard to get to published L/D. However what struck me is how far off the manual's numbers are at the high end and he doesn't mention it. Are many manufactures too optimistic at the fast end? No Nick, those polars are gospel to the manufacturers, they wouldn't fake'em! In case you are wondering, there's absolutely not gambling going on at Rick's Cafe, either. |
Casablanca is the best. A saying that keeps coming to mind as I do this is: Garbage in, garbage out. Another is measure with a micrometer and cut with an axe.
Who uses what polar? From what I can tell xcsoar and seeyou are using the manufacturer and winpilot is using Carl Herold, which is closer to Johnson. The book value at 100kts is 550 ft/min, Johnson shows 650. See my concern? I would like to bend xcsoar, seeyou and the cambridge away from the book values. |
You can make a custom polar in XCSoar and use your own numbers.
On 4/16/2016 11:01 AM, xcnick wrote: Casablanca is the best. A saying that keeps coming to mind as I do this is: Garbage in, garbage out. Another is measure with a micrometer and cut with an axe. Who uses what polar? From what I can tell xcsoar and seeyou are using the manufacturer and winpilot is using Carl Herold, which is closer to Johnson. The book value at 100kts is 550 ft/min, Johnson shows 650. See my concern? I would like to bend xcsoar, seeyou and the cambridge away from the book values. -- Dan, 5J |
On Saturday, April 16, 2016 at 4:55:01 PM UTC-7, Dan Marotta wrote:
You can make a custom polar in XCSoar and use your own numbers. thanks, I put 51=1.22 76=2.5 97=5 and we will see. seeyou I did at 50=1.21 65=1.8 80=3.07 but the Cambridge has only two points. Not sure what to fudge. Took me a week to find a 1995 computer with a serial port. Finally got the down audio to shut up. |
I have a Belkin USB to Serial adapter for my laptop. It worked great
with Vista, but doesn't work at all with 8.1. Fortunately for me, I had an old desktop computer that I dropped off in my hangar. On 4/16/2016 8:32 PM, xcnick wrote: On Saturday, April 16, 2016 at 4:55:01 PM UTC-7, Dan Marotta wrote: You can make a custom polar in XCSoar and use your own numbers. thanks, I put 51=1.22 76=2.5 97=5 and we will see. seeyou I did at 50=1.21 65=1.8 80=3.07 but the Cambridge has only two points. Not sure what to fudge. Took me a week to find a 1995 computer with a serial port. Finally got the down audio to shut up. -- Dan, 5J |
On Sunday, April 17, 2016 at 2:32:17 PM UTC+12, xcnick wrote:
On Saturday, April 16, 2016 at 4:55:01 PM UTC-7, Dan Marotta wrote: You can make a custom polar in XCSoar and use your own numbers. thanks, I put 51=1.22 76=2.5 97=5 and we will see. seeyou I did at 50=1.21 65=1.8 80=3.07 but the Cambridge has only two points. Not sure what to fudge. Took me a week to find a 1995 computer with a serial port. Finally got the down audio to shut up. Cambridge uses only two points, but one of the speeds has two constraints: 1) the L/D at that speed, AND 2) this is *best* L/D speed Therefore, together with the 2nd speed and sink rate, you have three constraints, same as the other programs. Three constraints uniquely specifies a parabola, which is what virtually all software assumes the polar curve is (at least above min sink): X*speed^2 + Y*speed + Z = sink The programs will use the information you input to calculate X, Y, and Z. For example for your XCSoar numbers 51=1.22 76=2.5 97=5 2601*X + 51*Y + 1*Z = 1.22 5776*X + 76*Y + 1*Z = 2.5 9409*X + 97*Y + 1*Z = 5 Enter these into any linear equation solver, for example at http://wims.unice.fr/wims/wims.cgi?+...+met hod=coef x = 0.0014749482401656, y = -0.13611842650104, z = 4.325699378881989 Put those into a spreadsheet and try with 51, 76, 97 and you'll see you get exactly 1.22, 2.5 and 5. However with 50, 65, 80 you get 1.2071, 1.7097, 2.8759 so the numbers you've put into seeyou are not exactly consistent. Putting your seeyou numbers into the solver: 2500*X + 50*Y + 1*Z = 1.21 4225*X + 65*Y + 1*Z = 1.8 6400*X + 80*Y + 1*Z = 3.07 x = 0.0015111111111111, y = -0.13444444444444, z = 4.154444444444445 I don't know which of those sets of inputs is best for you. If you use a SVD solver (Singular Value Decomposition) then you can input all six equations (or more!) and get a best fit solution for X, Y, and Z. Or, we could just say that something between them is close enough. Say: X=0.001485, Y=-0.135, Z=4.245 These give sink rates different from your inputs by +/- 0.25 fpm at 50&51 knots, +/- 6 fpm at 65&76 knots, and +/- 12 fpm at 80&97 knots. So, lets work with: 0.001485*speed^2 - 0.135*speed + 4.245 = sink Cambridge want different kinds of numbers. Best L/D speed Best L/D speed at 2 m/s sink The L/D is the reciprocal of the glide slope. i.e. if the L/D is 40 then the glide slope is 0.025. If the L/D is 100 then the glide slope is 0.01. etc. We'll work with glide slope for the moment. Glide slope is sink/speed. sink = 0.001485*speed^2 - 0.135*speed + 4.245 so glide slope = 0.001485*speed - 0.135 + 4.245/speed Best L/D means minimum glide slope, which happens where the 1st derivative of the slide slope is zero. Remembering high school calculus: 0.001485 - 4.245/speed^2 = 0 = best L/D speed = sqrt(4.245/0.001485) = 53.466 Glide slope at 53.466 = 0.001485*53.466 - 0.135 + 4.245/53.466 = 0.0238 Best L/D = 1/0.0238 = 42.03 For speed at 2 m/s sink, solve: 0.001485*speed^2 - 0.135*speed + 4.245 = 3.88769 (knots) or 0.001485*speed^2 - 0.135*speed + 0.35731 = 0 Any quadratic equation solver will give 2.73 knots and 88.18 knots. Ignore the answer that is below stall speed :-) So for Cambridge: Best L/D speed = 53.466 knots = 99.02 km/h Best L/D = 42.03 speed at 2 m/s sink = 88.18 knots = 163.3 km/h. |
Dan, I have the USB to serial working in modern windows, but the Cambridge software only had ports 1 to 4 as an option. The USB to serial wire was assigned a higher number like 8.
Were you able to reassign the wire to a lower number or find later Cambridge software with a larger selection of port numbers? Bruce, I did give you garbage. When the xcsoar numbers came out as a parabola I knew I screwed up big time. I guess those are the number generated when you choose discus. The actual numbers from Johnson show the kink some talk about so I don't expect them to fit a parabola. So I took my school boy ruler to the little graph on page 3 of the Johnson article and come up with the following. I guess I am looking for a quadratic equation near these numbers except 97 knots. Because of the kink 97 knots should be off the most. max L/d 42.5 @ 53kts min sink 115 ft/min @ 45kts 50kts 121 ft/min or 1.195kts or .615 m/s 60kts 160 ft/min or 1.58kts or .813m/s 65kts 195 ft/min or 1.925kts or .99m/s 76kts 270 ft/min or 2.666kts or 1.372m/s 80kts 308ft/min or 3.05kts or 1.569m/s 97kts 650ft/min or 6.42kts or 3.3m/s You gave me enough I should be able to learn some calculus. I was not able to get there this morning, but I will try again. Is the A,B,C of see you x y and z of a quadratic? |
Commercial polar routes? | General Aviation | 6 | January 28th 05 08:03 PM | |
Stemme S10-VT Polar | Catherine Conway | Soaring | 2 | December 21st 04 05:17 PM |
For Keith Willshaw... | robert arndt | Military Aviation | 253 | July 6th 04 05:18 AM |
1930s Navy side numbers. | JDupre5762 | Naval Aviation | 3 | September 24th 03 07:51 PM |
Is anyone still interested in CuSoft "Polar Explorer" program for PC? | Branko Stojkovic | Soaring | 1 | July 26th 03 01:06 AM |
