91.205 compass requirement
Old April 17th 16, 06:45 PM posted to rec.aviation.soaring
Default 91.205 compass requirement
Does the ClearNav bearing display satisfy the magnetic compass requirement of FAR 91.205?
Old April 17th 16, 07:29 PM posted to rec.aviation.soaring
Tony[_5_]
91.205 does not apply to almost all gliders.
Old April 17th 16, 10:52 PM posted to rec.aviation.soaring
I could not find a FAR that exempted gliders. Can you point me to the correct FAR or FAA ruling?
Old April 17th 16, 10:59 PM posted to rec.aviation.soaring
2G
Try the title:
Powered civil aircraft with standard category U.S. airworthiness certificates: Instrument and equipment requirements
Old April 17th 16, 11:43 PM posted to rec.aviation.soaring
Bill T
Unless the glider manual or TCDS lists the compass as required.
Old April 18th 16, 01:26 AM posted to rec.aviation.soaring
MNLou
For what it's worth -
Almost none of the new gliders displayed at the convention had compasses.
I was told that was because the FSDOs had said that the GPS driven displays were adequate.
I understand there is "chapter and verse" for the regs supporting that but I don't know what it is.
Lou
Old April 18th 16, 05:55 AM posted to rec.aviation.soaring
Jonathan St. Cloud
What about the minimum equipment specified in the POH for the aircraft? Have never seen a POH that did not have a compass listed as min equipment.
Lou
Old April 18th 16, 07:09 AM posted to rec.aviation.soaring
Recently checked my Ventus B manual no requirement for a compass. It is listed as " optional" .
Old April 18th 16, 02:27 PM posted to rec.aviation.soaring
MNLou
In my LAK17at manual it states as minimum equipment "magnetic direction indicator (compensated in an aircraft)". I believe most people have interpreted this to mean a compass.
Apparently, there is some other interpretation or wording in the newer manuals that allows a GPS magnetic direction indicator to be substituted.
Lou
Old April 18th 16, 03:19 PM posted to rec.aviation.soaring
Jonathan St. Cloud
My ASG-29 POH requires one magnetic compass. I tried to use a little $4 stick on commas, but the examiner would not license it without a "robust aviation compass". So I had to mount one on the glare shield. I have two electronic flux gate compasses, plus maps and eyes so I thought I could leave the whiskey compass, not so
Lou
Requirement of AW 139 pilot sanjay Rotorcraft 2 August 25th 08 10:06 AM
IFR Alternate Requirement gwengler Instrument Flight Rules 18 May 18th 05 02:26 PM
compass turns with high mounted compass (Cessna 152) Ray Instrument Flight Rules 22 April 7th 05 07:39 AM
CFI logging requirement [email protected] Owning 9 October 19th 04 07:11 PM
Mode S to become requirement? Bob Chilcoat Owning 6 July 14th 04 11:25 PM
