IFR Alternate Requirement
Old May 11th 05, 04:15 PM
gwengler
Default IFR Alternate Requirement
To my knowledge, in the US one must file an alternate IFR airport
regardless of the weather if the destination airport does not have an
IFR approach. Can someone please quote me the FAA regulation where
this is actually spelled out? Thanks!
Gerd
Old May 11th 05, 04:34 PM
On 11 May 2005 08:15:28 -0700, "gwengler"
Gerd
Sec. 91.169 IFR flight plan: Information required.
(a) Information required. Unless otherwise authorized by ATC, each
person
filing an IFR flight plan shall include in it the following
information:
(1) Information required under Sec. 91.153(a).
(2) An alternate airport, except as provided in paragraph (b) of
this
section.
(b) Exceptions to applicability of paragraph (a)(2) of this
section.
Paragraph (a)(2) of this section does not apply if part 97 of this
chapter
prescribes a standard instrument approach procedure for the first
airport of
intended landing and, for at least 1 hour before and 1 hour after
estimated time of arrival, the weather reports or forecasts, or any
combination of them, indicate--
(1) The ceiling will be at least 2,000 feet above the airport
elevation;
and
(2) The visibility will be at least 3 statute miles.
(c) IFR alternate airport weather minimums.
etc,,,
Old May 11th 05, 05:02 PM
Roy Smith
In article .com,
91.169(b). It's a little confusing, since it's worded as an
exception. If your destination does not have an SIAP, it doesn't meet
the requirements of the exception clause.
Actually, I just noticed a detail I never saw before. It says:
"... a standard instrument approach procedure to [...] the FIRST
AIRPORT OF INTENDED LANDING" (my emphasis).
So, it seems like I could file "HPN -D- BDR D/010 -D- BOS",
i.e. "White Plains, direct Bridgeport, ten minute delay (not sure if I
got the flight plan symbol right for that), direct Boston" and as long
as BDR doesn't doesn't require an alternate, I don't have to file one
for the BOS leg either, since BDR is my "first airport of intended
landing".
This seems rather stupid, but if you read the reg literally, that's
what it says.
Old May 12th 05, 03:14 PM
gregscheetah
Why are you trying to get out of filing an alternate? Is there some
reason that this is difficult to do for you?
I would suggest that you always file an alternate and forget about
having to memorize when, where, why and how. Much easier and
eventually may save you some confusing during a time of quick decision
making.
Greg
I
long
landing".
Old May 12th 05, 06:48 PM
Stan Gosnell
"gregscheetah" wrote in
ups.com:
making.
Filing an alternate shouldn't have any effect on your decision making at
the destination. Alternate requirements are for fuel planning only. As
soon as you take off, the alternate you filed becomes immaterial. ATC
doesn't know what alternate you filed, or if you filed one. When you get
to your destination and miss, then you need to make a decision on where
to go. You should have been keeping up on the weather at your
destination, your alternate, and other possible diversions. The
alternate you filed may not be the best place to go, for both weather and
personal convenience. Once you miss and decide to go somewhere else,
you're free to go anywhere you have the fuel to get to, and ATC will ask
you your intentions when you miss, having no idea where you want to go.
You now have to decide. If you want to blindly go to your filed
alternate without even thinking any further, you can, but make sure you
check the current weather first. I often file an alternate with no
intention whatsoever of ever going there.
Regards,
Stan
"They that can give up essential liberty to obtain a little temporary
safety deserve neither liberty nor safety." B. Franklin
Old May 13th 05, 02:47 PM
MJC
Pilots do too many stupid things already that get themselves killed.
Requiring an alternate is nothing more than a simple attempt to make pilots
do something that they should plan for anyway. Even when I file an
alternate, I always like to have plates for another "personal" alternate so
that I have one more choice if weather goes bad at my destination.
I don't see why this reg should bother anyone enough to even bring it up
for discussion.
MJC
"Stan Gosnell" wrote in message
ups.com:
making.
Regards,
Stan
Old May 13th 05, 04:28 PM
You don't need plates to have another choice.
If need be, ask ATC to read the approach. I'm not suggesting a
cavalier attitude about having plates, but no one should ever choose
to accept a less desirable alternative because plates are not
available, for whatever reason. ATC has all the information necessary
to follow an approach procedure, and they will provide it to you if
required.
Old May 13th 05, 08:14 PM
Antoņio
making.
Greg
I can see a couple reasons why one would not wish to file an alternate.
If I recall correctly, you must have enough fuel to fly to the alternate
and then 45 minutes beyond. If the alternate is say, 30 minutes away,
that would require an extra hour and 15 minutes of fuel. This could
affect weight and balance calculations and maybe the necessity to plan
an extra fuel stop.
Antonio
Alternate minimums same as forecast weather [email protected] Instrument Flight Rules 17 February 21st 06 10:45 PM
FBO Insurance requirement for tie-downs Chris Owning 25 May 18th 04 07:24 PM
Alternate Intersection Name in Brackets? Marco Leon Instrument Flight Rules 7 January 22nd 04 04:55 AM
Strange wording in Commercial experience requirement David Brooks Piloting 5 January 18th 04 06:09 PM
Alternate requirements Anthony Chambers Instrument Flight Rules 8 September 17th 03 09:45 PM
Copyright Š2004-2025 AviationBanter.
