Flarm Ver 6.06 Download
Old April 24th 16, 03:06 AM posted to rec.aviation.soaring
Dan Daly[_2_]
Default Flarm Ver 6.06 Download
On Saturday, April 23, 2016 at 9:23:51 PM UTC-4, Dave Springford wrote:
Well, that fix didn't work on the portable units I am trying to update. One more attempt tomorrow. I"ll try changing the file name from powerflarm_6.06_8249.fw
to the same format as last years successful firmware updates (from the same SD card. PF6.06_8249.fw.
As to Erik's question, the CSV file that downloads to the card or USB shows the current fw version.
The only other problems I have had with updating was bad USB sticks (on COREs). Perhaps try another microSD (or reformat, then retry)?
Dan
Old April 24th 16, 03:45 AM posted to rec.aviation.soaring
Dave Springford
I'm using the same SD card as last year, and it has not been used for anything since then either.
Old April 24th 16, 04:19 AM posted to rec.aviation.soaring
Andrew Ouellet
Try updating through the menu options after startup.
Old April 25th 16, 12:55 AM posted to rec.aviation.soaring
Dave Springford
I could not find any menu option to do that after briefly going through the menu.
Old April 25th 16, 07:09 AM posted to rec.aviation.soaring
Andrew Ouellet
What version are you running now? It may tell you on the startup screen depending on the version. I updated to 6.06 last week and it was through an active menu option - after thinking it odd the update didn't happen automatically on startup. I updated from the previous 6.0x version.
Old April 25th 16, 09:06 PM posted to rec.aviation.soaring
Dave Springford
The Portable is currently running 6.02.
I"ll have to look through the menu again and see if I can find the update option.
Old April 25th 16, 09:13 PM posted to rec.aviation.soaring
Dave Nadler
Dave - PF Portable Menu option Info Update
See you at Bermuda High?
Best Regards, Dave
trying to work out how you connect the flarm view 57 to mini box flarm running a V7 and Oudie Michael Marshall[_2_] Soaring 3 April 10th 16 04:13 AM
trying to work out how you connect the flarm view 57 to mini box flarm running a V7 and Oudie Michael Marshall[_2_] Soaring 0 April 8th 16 08:57 PM
Information for all users of Flarm, OEM FLARM supplier and Flarm PowerFlarm [email protected] Soaring 28 March 12th 16 04:31 AM
Ugh. Flight trace didn't download off FLARM brick Kurt Thams Soaring 9 June 10th 15 12:37 PM
flarm flight log download through Oudie? Matt Herron Jr. Soaring 4 January 21st 15 02:28 AM
