I'm using the same SD card as last year, and it has not been used for anything since then either.
Try updating through the menu options after startup.
I could not find any menu option to do that after briefly going through the menu.
What version are you running now? It may tell you on the startup screen depending on the version. I updated to 6.06 last week and it was through an active menu option - after thinking it odd the update didn't happen automatically on startup. I updated from the previous 6.0x version.
The Portable is currently running 6.02.
I"ll have to look through the menu again and see if I can find the update option. |
Dave - PF Portable Menu option Info Update
See you at Bermuda High? Best Regards, Dave |
Thanks Dave,
I just looked in the manual and found that, (IAEF - RTM) but I don't remember having to do that last year. Seems to me that it found the .fw on the card on start up and did it automatically the previous times. See you at Bermuda High. |
trying to work out how you connect the flarm view 57 to mini box flarm running a V7 and Oudie | Michael Marshall[_2_] | Soaring | 3 | April 10th 16 04:13 AM |
trying to work out how you connect the flarm view 57 to mini box flarm running a V7 and Oudie | Michael Marshall[_2_] | Soaring | 0 | April 8th 16 08:57 PM |
Information for all users of Flarm, OEM FLARM supplier and Flarm PowerFlarm | [email protected] | Soaring | 28 | March 12th 16 04:31 AM |
Ugh. Flight trace didn't download off FLARM brick | Kurt Thams | Soaring | 9 | June 10th 15 12:37 PM |
flarm flight log download through Oudie? | Matt Herron Jr. | Soaring | 4 | January 21st 15 02:28 AM |
