On Fri, 2 Apr 2004 02:23:27 -0500, "Kevin Brooks"
wrote: "John Cook" wrote in message .. . On Thu, 01 Apr 2004 22:16:28 -0700, Scott Ferrin wrote: Gotta question about the following: ""USAF officials also rejected the forecast that the service will need to spend $11.7 billion to introduce air-to-ground capabilities in the F/A-22. Roche says planned upgrades, including a new radar and small-diameter bomb, are budgeted and would cost less than $3.5 billion. . . "" So when they say "new radar" are the talking about replacing the APG-77 with an APG-XX or are they just talking about new software or a mod of the -77? I'd ask what the hell they need a new radar for as the F-22 itself is not even in service yet and it's *current* radar should be considered "new" but seeing how it's been over a decade since the YF-22 flew it's no wonder. OK this is from memory... and the sources are not strictly 'official'. I had heard some rumours that the F-35 and F-22 AESA antennae will be merged because the MMIC's from the F-35 will be retrofitted to the F-22's ( they are very expensive and larger.) The number of MMIC's may also be the same in both aircraft to make a common 'cheap' AESA antennae (1200 IIRC). See http://www.irconnect.com/noc/press/p....mhtml?d=59037 "Northrop Grumman Begins Flight-Testing New Radar for F/A-22 Raptor BALTIMORE, June 11, 2004 -- Northrop Grumman Corporation (NYSE:NOC) has successfully conducted the first flight test of a new, fourth-generation variant of the AN/APG-77 active electronically scanned array radar for the U.S. Air Force's F/A-22 Raptor air dominance fighter aircraft. The new design is intended to reduce the production and maintenance costs of the Raptor's third-generation radar by adapting the design that was implemented successfully in the AN/APG-81 radar for the F-35 Joint Strike Fighter and the AN/APG-80 for the Block 60 F-16 fighter. This newest variant requires significantly fewer parts than the third-generation, and the production line relies on a greater degree of automation. In addition, Northrop Grumman's Electronic Systems sector is developing software for the new radar that will enable it to perform high-resolution mapping of ground targets. This will permit true all-weather, precision strike capability that will transform the air dominance fighter into a multi-mission asset. "We are proud to have developed this new capability for the F/A-22," said Jerry Dunnigan, director of F/A-22 Radar Programs at Northrop Grumman. "We believe that the transformational capabilities of high-resolution ground-mapping and automatic target cueing will ensure that Raptor pilots have all the information they need when they go in harm's way." Based on current Department of Defense plans, Northrop Grumman will deliver approximately 203 of the new radars. These include retrofits for some of the third-generation radars already in service on operational aircraft. Northrop Grumman is conducting the flight-test program aboard one of its BAC 1-11 flying testbed aircraft. The company produces the radar under contract to The Boeing Company's (NYSE:BA) Integrated Defense Systems unit, which has responsibility for integrating the avionic systems for the F/A-22 program, which is led by Lockheed Martin's (NYSE:LMT) Aeronautics Company. Raytheon Systems of McKinney, Tex., is a joint-venture partner on the radar. " Cheers John Cook Any spelling mistakes/grammatic errors are there purely to annoy. All opinions are mine, not TAFE's however much they beg me for them. Email Address :- Spam trap - please remove (trousers) to email me Eurofighter Website :- http://www.eurofighter-typhoon.co.uk |
![]() "John Cook" wrote in message news ![]() On Fri, 2 Apr 2004 02:23:27 -0500, "Kevin Brooks" wrote: "John Cook" wrote in message .. . On Thu, 01 Apr 2004 22:16:28 -0700, Scott Ferrin wrote: Gotta question about the following: ""USAF officials also rejected the forecast that the service will need to spend $11.7 billion to introduce air-to-ground capabilities in the F/A-22. Roche says planned upgrades, including a new radar and small-diameter bomb, are budgeted and would cost less than $3.5 billion. . . "" So when they say "new radar" are the talking about replacing the APG-77 with an APG-XX or are they just talking about new software or a mod of the -77? I'd ask what the hell they need a new radar for as the F-22 itself is not even in service yet and it's *current* radar should be considered "new" but seeing how it's been over a decade since the YF-22 flew it's no wonder. OK this is from memory... and the sources are not strictly 'official'. I had heard some rumours that the F-35 and F-22 AESA antennae will be merged because the MMIC's from the F-35 will be retrofitted to the F-22's ( they are very expensive and larger.) The number of MMIC's may also be the same in both aircraft to make a common 'cheap' AESA antennae (1200 IIRC). None of the above was from me, so why did you leave me in the poster list? Brooks See http://www.irconnect.com/noc/press/p....mhtml?d=59037 "Northrop Grumman Begins Flight-Testing New Radar for F/A-22 Raptor BALTIMORE, June 11, 2004 -- Northrop Grumman Corporation (NYSE:NOC) has successfully conducted the first flight test of a new, fourth-generation variant of the AN/APG-77 active electronically scanned array radar for the U.S. Air Force's F/A-22 Raptor air dominance fighter aircraft. The new design is intended to reduce the production and maintenance costs of the Raptor's third-generation radar by adapting the design that was implemented successfully in the AN/APG-81 radar for the F-35 Joint Strike Fighter and the AN/APG-80 for the Block 60 F-16 fighter. This newest variant requires significantly fewer parts than the third-generation, and the production line relies on a greater degree of automation. In addition, Northrop Grumman's Electronic Systems sector is developing software for the new radar that will enable it to perform high-resolution mapping of ground targets. This will permit true all-weather, precision strike capability that will transform the air dominance fighter into a multi-mission asset. "We are proud to have developed this new capability for the F/A-22," said Jerry Dunnigan, director of F/A-22 Radar Programs at Northrop Grumman. "We believe that the transformational capabilities of high-resolution ground-mapping and automatic target cueing will ensure that Raptor pilots have all the information they need when they go in harm's way." Based on current Department of Defense plans, Northrop Grumman will deliver approximately 203 of the new radars. These include retrofits for some of the third-generation radars already in service on operational aircraft. Northrop Grumman is conducting the flight-test program aboard one of its BAC 1-11 flying testbed aircraft. The company produces the radar under contract to The Boeing Company's (NYSE:BA) Integrated Defense Systems unit, which has responsibility for integrating the avionic systems for the F/A-22 program, which is led by Lockheed Martin's (NYSE:LMT) Aeronautics Company. Raytheon Systems of McKinney, Tex., is a joint-venture partner on the radar. " Cheers John Cook Any spelling mistakes/grammatic errors are there purely to annoy. All opinions are mine, not TAFE's however much they beg me for them. Email Address :- Spam trap - please remove (trousers) to email me Eurofighter Website :- http://www.eurofighter-typhoon.co.uk |
![]() None of the above was from me, so why did you leave me in the poster list? Brooks My deepest apologies, its a lesson we all can learn from in this NG Cheers. John Cook Any spelling mistakes/grammatic errors are there purely to annoy. All opinions are mine, not TAFE's however much they beg me for them. Email Address :- Spam trap - please remove (trousers) to email me Eurofighter Website :- http://www.eurofighter-typhoon.co.uk |
