Jim is fairly correct in the terminology he is using.
There are Mode A and Mode C and Mode S interrogations and what a transponder replies with depends on that interrogations (and if it support that type of interrogation, a "Mode S Transponder" Supports Mode A, C, and S interrogations. A "Mode C" transponder supports Mode A and C interrogations) Lots of people use "Mode C" or "Mode C interrogation" to mean any altitude interrogation even though most Mode S transponders will usually be interrogated via Mode S type interrogation to return altitude data. They'll respond perfectly like a Mode C transponder for legacy Mode C interrogators. Legacy SSR issues interleaved Mode A and C interrogations, modern SSR adds Mode S. TCAS does Mode C and Mode S only. Sone GA PCAS systems do legacy mode C only. Mode S interrogators (SSR and TCAS) utilize a trick (using side lobe suppression) to prevent Mode S capable transponders replying to their Mode A or C legacy interrogations. On Monday, May 9, 2016 at 9:26:43 AM UTC-7, David Kinsell wrote: On Mon, 09 May 2016 08:32:58 -0700, JS wrote: On Monday, May 9, 2016 at 8:16:44 AM UTC-7, David Kinsell wrote: The bigger question is how well your PF is handling your Mode C transponder? It has trouble filtering out your own transmissions, may want to consider upgrading to Mode S for best results. I assume you have Aggressive filtering selected, and you are receiving Mode C? Using aggressive filtering and a Trig TT22 that's being interrogated by Mode C. The flashing blue dot is boring. Until checking the "use TXP altitude" box, every pull-up brought a collision warning. This is my second PowerFLARM used in conjunction with Mode S. The previous installation of PF with Trig TT21 wasn't a problem. But that might have been using better FLARM firmware? Jim Mode C doesn't interrogate anything, it responds to ground radar or TCAS. With no Mode C in your ship, can't imagine Aggressive filtering would be needed. Probably best not to use it. -Dave |
Sorry another r.a.s. typo. " Sone GA PCAS systems do legacy mode C only. " should be "Some GA TCAD systems do legacy mode C interrogations only." An example system is the L-3 SkyWatch, it's a Mode C interrogator only, no Mode S. And obviously PCAS does not do any interrogations, it just listens to responses from transponders to other interrogations.
BTW Those legacy Mode C only interrogators help mess things up for deduplicatiing 1090ES and FLARM signals from traffic. Since the reply to a legacy Mode C interrogation, even from a Mode S transponder, does not include the aircraft's ICAO address a PowerFLARM can't easily know to suppress the PCAS alert for a target it also has via ADS-B/1090ES or FLARM. |
Flarmview and Powerflarm Core Config File? | Papa3[_2_] | Soaring | 4 | May 18th 15 10:51 PM |
Borgelt B50 and PowerFLARM Question | Paul Remde | Soaring | 5 | May 13th 15 08:48 PM |
Question about PowerFlarm IGC recording rate | SoaringXCellence | Soaring | 5 | June 6th 13 11:51 PM |
Stupid PowerFLARM Question | Peter von Tresckow | Soaring | 9 | March 1st 12 11:50 AM |
PowerFLARM Mode S question | kirk.stant | Soaring | 54 | October 26th 10 02:51 PM |
