Werker SLA batteries? (... better than PowerSonic?)
Old May 10th 13, 08:11 PM posted to rec.aviation.soaring
Default Werker SLA batteries? (... better than PowerSonic?)
On Monday, April 29, 2013 8:10:04 PM UTC-5, 2NO wrote:
I'm growing weary of my PowerSonic (PoS) batteries crapping out a few minutes after their 1 year warranty expries.
Are Werker batteries any better? ... or are they essentially the same?
The salesman at Batteries Plus said they pretty much stopped selling PS because they were having quality issues ...
Old May 10th 13, 08:12 PM posted to rec.aviation.soaring
Old May 12th 16, 08:20 PM posted to rec.aviation.soaring
PowerSonic batteries are made in China and they do indeed SUCK. I will no longer use them in medical devices. I use Werker batteries and they last far longer and work much better. As the name implies they must be made in Germany and just like a VW, run forever.
Old May 13th 16, 02:22 AM posted to rec.aviation.soaring
6PK
The best but equally expensive are the Sonnenschein dryfit batteries, made in Germany, par non. I ran 14v 10 ah for many years, and have a pair back from 2005 that I will still occasionally put on charge and do an hour or so locally. Of course for longer flights I will use newer ones (and also some LiPo ones, equally reliable). Sonnenschein dryfit NEVER failed me. These are also hard to get but obtainable. If need be, I can post a source.
Old May 13th 16, 09:23 AM posted to rec.aviation.soaring
bumper[_4_]
"Werker" may have sounded German, but that's as far at it went. Werker was a store brand name at Batteries Plus. Now Batteries + Bulbs, and have apparently dropped the name Werker.
If you blow the picture at the link up, you can clearly see this Werker SLA is "made in china" - - probably at the very same factory all the other 12 volt 7 to 10 AH SLA's are made!
http://www.ebay.com/itm/WKA12-7F-12V...-/191412460050
Switching to LiFePO4.
bumper
Old May 13th 16, 01:28 PM posted to rec.aviation.soaring
SF
Switch to Lithium Iron Phosphate Batteries. The chemistry does not supply it's own oxidizer like the Lithium Ion batteries in you laptops, so it's much safer from a fire hazard point of view. Yes they cost more up front, but they last longer so in the long run they end up costing less. I'm still running the original K2 batteries that were the subject of my battery article in Soaring sever years ago. They still work fine, no battery issues since the switch. The electronics, and especially the radio like the fact that the voltage never drops below 12V, after 5 hours in the air with a full panel of electronic gizmos.
SF
Old May 13th 16, 03:22 PM posted to rec.aviation.soaring
6PK, can you post your source for the german Sonnenschein batteries? It's probably time to obtain another replacement since I've been flying with one for 6 years with no problems. I use a 10ah,12v unit.
  #28
Old May 13th 16, 03:26 PM posted to rec.aviation.soaring
6PK, can you post your supplier info for the Sonnenschein batteries?
These are the real deal. Never any issues.
  #29
Old May 13th 16, 03:37 PM posted to rec.aviation.soaring
6PK
Here you go guys ( there may very well be others);
http://www.ecovantageenergy.com/cata...ms/item445.htm
  #30
Old May 13th 16, 03:46 PM posted to rec.aviation.soaring
6PK
Here is one more;
http://www.sonnenschein.org/A500.htm
Batteries Included Mitchell Holman Aviation Photos 0 September 21st 08 12:33 AM
AGM Batteries Dave Anderer Owning 13 March 29th 08 07:38 PM
2-Batteries [email protected] Soaring 69 January 4th 07 04:09 AM
160 new batteries Mal Soaring 0 October 27th 06 11:36 AM
Airplane Batteries [email protected] Piloting 79 January 30th 06 04:50 AM
