but that requires extra components and (therefore) extra expense.
Probably right. Simplest solution is for them to do a QA check on the antennas before delivery with the unit. So easiest way to check the Pflarm A antenna, if you have access to the box itself is simply unscrew it from port A. And get out an ohm meter and carefully probe the inner core socket(middle of the white nylon bush) vs the outer "nut" which is tied to the shield. It should read infinite. If using the continuity feature of your multimeter it should NOT sound the high pitched beeeeep. verify again. if good, carefully screw the antenna back onto the proper/same port A and careful not to cross-thread. do not attempt to attach to any other port. |
I should point out that this will detect only one type of failure. Another one could be a disconnect which make the antenna similarly useless. There could be other failure modes. So if you still have issue try to borrow an antenna from someone else or just spend the $30 or so for a new antenna. Another option is to swap the antennas for testing (they are almost identical) but this will require a reverse gender adapter.
Ramy |
Dreaming of a BETTER PowerFLARM antenna | [email protected] | Soaring | 27 | November 12th 15 03:24 PM |
second PowerFlarm antenna | Andrzej Kobus | Soaring | 10 | November 2nd 15 03:39 PM |
PowerFLARM antenna separation | kirk.stant | Soaring | 5 | June 5th 15 05:42 AM |
PowerFlarm antenna recommendation | Sam Discusflyer[_2_] | Soaring | 3 | April 7th 13 08:41 PM |
PowerFlarm antenna install | Sam Zimmerman | Soaring | 10 | November 11th 10 09:54 PM |
