Great advice. I'm planning to fly power and inspect some of the airports in question. Both the ships I fly are standard class CG hook.
Generally the paved strips I'm considering (with edge lights) are 72' wide to 75' wide. Considering runway lights are at least a few feet beyond the runway edge, it seem 75' would work pretty well, even if a wing dropped before I came to a complete stop. Seems you have to have at least the center line, or hold wings level till a complete stop in this situation. Aerotow with our Pawnee, unassisted seems like a more difficult proposition based on above runway. But with the JJ wing runner, or a human wing runner, maybe it's ok. Our STD Cirrus really likes to drop a wing unexpectedly pre 30kts or so. Another subject, but I think I need to get better at using both aileron AND rudder to counter this. Aileron only doesn't usually cut it. I worry that if I apply full rudder it's going to make the ship veer off to one side. |
Practice unassisted TO's at your home field.
Slight cross angle of the glider to the runway, tip on the ground. Say you angle right a bit, put the left tip down (keep in mind any crosswind) such that it's drag on the ground aligns you as you accelerate. Part dive brakes can help with flow over the ailerons in the first hundred feet or so. Don't forget to close and lock the dive brakes. |
On Thursday, 26 May 2016 09:44:39 UTC-6, Charlie M. (UH & 002 owner/pilot) wrote:
Practice unassisted TO's at your home field. Slight cross angle of the glider to the runway, tip on the ground. Say you angle right a bit, put the left tip down (keep in mind any crosswind) such that it's drag on the ground aligns you as you accelerate. Part dive brakes can help with flow over the ailerons in the first hundred feet or so. Don't forget to close and lock the dive brakes. When I self launch, wheels on the wings assist this, the tow plane will stand on the brakes for 15 or seconds and create prop wash that helps with lifting the down wing and getting wind over the wings. YEMV |
On Thursday, May 26, 2016 at 6:44:39 PM UTC+3, Charlie M. (UH & 002 owner/pilot) wrote:
Practice unassisted TO's at your home field. Slight cross angle of the glider to the runway, tip on the ground. Say you angle right a bit, put the left tip down (keep in mind any crosswind) such that it's drag on the ground aligns you as you accelerate. Part dive brakes can help with flow over the ailerons in the first hundred feet or so. Don't forget to close and lock the dive brakes. Maybe if you have a CG hook. In which case angle into the crosswind and put the other tip down. With a nose hook, If you angle right and put the left wing tip down then both rope and tip will be swinging you to the left, which can be a recipe for a violent fishtailing. Better to put the same tip down so the rope is pulling you left and the tip is pulling you right, and you'll be in perfect control. The amount of angling is not big. Definitely try where there is some width available at your home field to find the right balance of tip turning you one way and rope the other. Having the down tip going faster also makes it easier to pick it up. |
Don't even try to take-off unassisted with a CG hook. It won't go well. I fly a standard class glider with a CG hook. I carry a JJ WingRunner in the cockpit with me on every flight and have used it in the very scenario you are anticipating - landout at a paved strip and aerotow out un-assisted. Entirely uneventful. It breaks down into very small components and is stowed in the baggage compartment until needed. Then assembly and attachment to the wingtip is quick and easy as per JJ's instructions. I consider it an essential piece of equipment and prefer to use that rather than an untrained human wingrunner.
Tom |
Yes, that's a product I've been looking for. Ordered mine today. Might come in handy in Minden where I spend a week every year. Thanks for the tip.
Why do you say that? I've taken off unassisted in my LAK-17a (CG hook
only) without a second thought. I think there's way too much fear around CG hooks. On 5/26/2016 5:20 PM, Tom Nau wrote: Don't even try to take-off unassisted with a CG hook. It won't go well. -- Dan, 5J |
It's not possible in my ship, a '28, without a wingtip wheel.
Tom |
Understood.
However, years back my partner and I launched our LS-6a (no tip wheels) unassisted, though using a stick for a wing stand. I was in the tug and he was in the glider. We had to make a couple of attempts due cross winds causing the wing to rise and the stick to drop. Circumstances of the day did not allow a trailer retrieve so I flew out to get him. I wouldn't do that routinely... On 5/26/2016 7:30 PM, Tom Nau wrote: It's not possible in my ship, a '28, without a wingtip wheel. Tom -- Dan, 5J |
Glad I read this now, may have prevented me from unassisted aero retrieves from a grass field a in a ASW-20, 24, 27 & 28 all with CG hooks......... Oh, never had an issue with those tows....... ;-)....... YMMV.......
selecting wheels and tyres | jan olieslagers[_2_] | Home Built | 4 | March 11th 10 08:47 AM |
Another Cherokee II Landout | [email protected] | Soaring | 2 | September 22nd 08 04:36 AM |
Dry Lake Landout | Hal[_2_] | Soaring | 1 | July 9th 07 09:23 PM |
U.S. & ISRAEL SELECTING TARGETS FOR CRUISE MISSILE FIRST-STRIKE ATTACK | dontcowerfromthetruth | Naval Aviation | 7 | August 8th 06 02:22 PM |
Landout Laws | Charles Petersen | Soaring | 90 | February 26th 04 02:09 AM |
