You could plumb the varios in series, but then any internal resistance impacts the response of the other vario. Not ideal, but it would function correctly.
Parallel could work, but only if you use a 0.9L flask. If you are committed to using 2 mechanicals, then the optimum arrangement would be a T and then each vario has it's own 0.45L flask. |
Thanks. I was wondering about the possible logic of using a 0.9L flask but I guess it is easiest to just use a second 0.45L. I have a couple of extra flasks so not a problem. And, it's not two mechanicals, it's a Winter mechanical and an LX-100 in a friend's ASW-19. We pulled out his silent Cambridge Mk IV and broken PZL.
You may want to consider plumbing the LX-100 with electronic compensation. That way if the TE gets damaged/obstructed you have an independent backup system.
ClearNav Vario Question | Dan Marotta | Soaring | 2 | April 3rd 16 02:42 AM |
Antenna installation question | [email protected] | Soaring | 6 | February 28th 08 02:14 PM |
Vario loudspeaker question | Greg Arnold | Soaring | 10 | January 26th 06 10:21 PM |
Another Vario question | Nick Danger | Soaring | 3 | January 2nd 06 06:29 PM |
Vario Installation in PW-5 | BlueGliderGuy | Soaring | 5 | May 12th 05 12:28 PM |
