On Tuesday, May 31, 2016 at 12:03:09 PM UTC-5, wrote:
Once flying it's self contained. No need for a data connection. On Tuesday, May 31, 2016 at 8:22:05 AM UTC-7, wrote: How badly does it eat up data? Any negatives from users? Have been looking at it for awhile. THough not IGC verified it seems to be about on par with Oudie |
On Tuesday, May 31, 2016 at 11:30:59 AM UTC-7, wrote:
On Tuesday, May 31, 2016 at 12:03:09 PM UTC-5, wrote: Once flying it's self contained. No need for a data connection. On Tuesday, May 31, 2016 at 8:22:05 AM UTC-7, wrote: How badly does it eat up data? Any negatives from users? Have been looking at it for awhile. THough not IGC verified it seems to be about on par with Oudie It's personal preference, but I would put it head and shoulders above Oudie. Approximately a 30 year advance in UI by comparison. If you like a TTY, then Oudie is for you. |
![]() Any negatives from users? Have been looking at it for awhile. THough not IGC verified it seems to be about on par with Oudie I've used mine about a dozen times now. Several people told me that the GPS in the iPhone was not accurate enough. Well my first few flights had me taking off about 50-100' from where I actually did. But that is close enough for navigation but probably not comp turn points. So I got the Bad Elf and the accuracy is spot on. The only thing is iGlide will only go into vertical view and not landscape putting my bad elf connection on the bottom of the iPhone. My knee hit the Bad Elf and broke the connection inside. Bad Elf replace for free and now I slid my iPhone up so I would not hit the bottom of it. I also move the entire mount out of the way when I exit. iGlide is expensive, but very nice and very easy to use. And the iPhone 6Plus S is sunlight readable and is mounted perfect for face timing my wife. ![]() |
There is also winpilot for iPhone/iPad.
Ramy |
I have the lite version of Iglide, it is cheap ($35 range)
It is perfect for a backup glide computer. By far the easiest most user friendly UI of anything out there. This is important if you end up needing it but have not used it for a while. |
On Wednesday, June 1, 2016 at 6:19:14 AM UTC-5, joesimmers wrote:
I have the lite version of Iglide, it is cheap ($35 range) It is perfect for a backup glide computer. By far the easiest most user friendly UI of anything out there. This is important if you end up needing it but have not used it for a while. Great! Can you pair it with a Nano 3 for increased GPS accuracy and to take advantage of the Nanos capabilities? |
On Tuesday, May 31, 2016 at 8:59:12 PM UTC-7, Ramy wrote:
There is also winpilot for iPhone/iPad. Ramy Ramy Do you have any feedback on it? |
iPhone 5 vs iPhone 6 sunlight readability | 6PK | Soaring | 2 | March 22nd 16 11:54 PM |
iGlide update for iPhone 6 (4.7 inch) and iPhone 6 plus (5.5 inch) | Sean Fidler | Soaring | 29 | March 9th 15 03:24 AM |
Free flight computer software for iPad/iPhone | WinPilot | Soaring | 31 | December 11th 13 01:22 AM |
Loading flight data to iPhone from serial port devices | Craig Funston | Soaring | 5 | July 25th 11 08:09 PM |
iPhone flight tracking | fjohnson | Products | 0 | August 19th 09 11:03 AM |
