Blanik L13AC AD requiring Eddy Current and Hardness Testing
Old June 17th 16, 10:47 PM posted to rec.aviation.soaring
Default Blanik L13AC AD requiring Eddy Current and Hardness Testing
Have you looked into the cost associated with simply buying a hardness tester and an eddy current tester? I don't know the specific requirements, but a quick search on eBay shows a number of both at fairly reasonable prices. No reason why you couldn't put them back on eBay after you are done and recoup most of your investment.
Old June 18th 16, 12:15 AM posted to rec.aviation.soaring
Possibly stupid question on my part........ say you have the correct tools, do you need to be trained/certified to announce the results of using those tools?
My guess is "YES".........,
Old June 18th 16, 01:17 AM posted to rec.aviation.soaring
Using a hardness tester is quite simple. It may require that an A&P needs to witness the test, but using the tester will not be an issue as long as you can pisition the tester on the part (no funky geometry).
The internet is a wealth of information. Maybe try youtube and see what you find on the eddy current testing process. It may not be that hard to determine that testing these parts is not that hard and then you've aquired a valuable skill ad well.
Blanik L13AC value Ramy Soaring 5 March 21st 12 09:02 PM
FAA requiring re-registration of airplanes, and then again every 3years Justin Rizor Soaring 9 July 23rd 10 06:17 PM
Eddy Currents [email protected] Piloting 10 December 25th 07 01:19 AM
CAP232 from Eddy Dussau Rie Janssen Aerobatics 4 July 15th 04 04:18 PM
CAP232 from Eddy Dussau Rie Janssen Aerobatics 0 March 23rd 04 01:06 PM
