We have also noticed a decrease in range with the update to 6.05.xxxx firmware.
Pretty easy to document with the Flarm Range checker using last years files for comparison. Yesterday I updated to 6.06 and upgraded my Flarmnet file and lost the Flarmnet feature at least with the other glider I was testing with. The Flarmnet feature might be the result of updating some for the Flarm information on the other glider. (Mode S ID, did not change) Going to test today with a glider that their flarm setting has not been changed to see if it is my Flarm or the other Flarm causing the competition # not to show on my butterfly display. Brian |
I had plenty of flights since I upgraded and did not notice any degradation.. In the contrary I noticed significant improvement in range with couple of friends but this was due to antenna issues they had in the past. Detection range seem to be 2-4 miles, occasionally further. As for contest IDs, indeed some folks no longer showing their contest ID, but most do. Not sure what is causing this.
Ramy |
Checked flarmnet feature with another flarm today, it worked just fine. So pretty sure issue was that the 1st glider flarmnet setting had just not updated on the flarmnet website yet.
Brian |
PowerFLARM Portable Firmware Update: 6.02 | Paul Remde | Soaring | 15 | April 10th 15 03:13 PM |
PowerFlarm Problems | Blake Seese 9V | Soaring | 7 | August 14th 14 06:38 PM |
PowerFLARM firmware v3.00 released (feature complete) | FLARM | Soaring | 42 | July 24th 14 09:24 PM |
unusual PowerFlarm problems | Mitch Polinsky[_2_] | Soaring | 4 | June 25th 13 06:02 AM |
PowerFLARM Portable - Firmware Update Available - Mode C Traffic Now Supported | Paul Remde | Soaring | 24 | January 22nd 12 01:50 AM |
