Your suggestion to report this to the Feds is worth serious consideration, particularly since the locking mechanism cannot be inspected without cutting into the frame. The "catch 22" is a bit rhetorical; what would prompt anyone from creating a window to inspect the thing unless there was already a problem? An A/D? For each Grob of this type, there are 4 bolts to check for each of the 2 canopies. Not much of a problem on the ground, but if you wanted to egress at altitude, the unlocked left side may prevent bailout even though the right-side emergency release worked.
Good thoughts, Thanks. Mike |
Double Release Failure on Tow | Piet Barber | Soaring | 20 | June 8th 16 07:31 PM |
Tost release failure | Bill D | Soaring | 24 | August 20th 13 10:49 AM |
TOST Release Failure - Two Uncommanded Release's | [email protected] | Soaring | 11 | October 13th 12 10:23 AM |
Grob 102 Astir CS Canopy | GARY BOGGS CFIG | Soaring | 1 | October 3rd 09 06:49 PM |
Double Release Failure | ZZ | Soaring | 35 | September 11th 09 03:29 AM |
