The ISU contains compass sensors; so
the same precautions as mounting a compass apply as far as magnetic fields are concerned. The Installation manual does a thorough job in specifying minimum distances from magnetic sources such as battery wires, speakers and compasses. I relocated my battery selector and wires to the bottom of my panel. Happily the fuses were already there. The radio was also moved down into a hole vacated by a Cambridge. The boat compass on the glareshield was tossed - the hole now accommodates PowerFLARM antennae. In Canada the Air Glide qualifies as a magnetic direction indicator. Then there's the geometric requirements. I leveled my glider according to the Maintenance Manual directions for CG measurement. Don't expect the panel to be 90° off the level flight attitude. Most likely it will be something else. Those with a tilting panel with access behind the panel accomplished by removing the canopy and glareshield need to support the panel with canopy removed in the same position as when the canopy is in. I cut a basswood plank from a hobby shop for the ISU platform with bevels to fit the panel and other side of the instrument binnacle. A foam block raises the ISU to just below the glareshield. Once you have the ISU on the platform and hooked up to the vario with the glider leveled, you can use the info boxes to show pitch and roll angles. Shim to get to zero. Nothing better to keep a glider owner occupied over the winter. |
Glide computer | Mark Siegelberg | Soaring | 1 | January 13th 07 01:08 PM |
Best Glide computer and why | Roger | Soaring | 10 | October 24th 06 08:28 PM |
Glide Loops | [email protected] | Soaring | 0 | April 29th 06 05:55 PM |
JSW Glide Calculator | snaproll59 | Soaring | 5 | November 7th 04 04:01 PM |
SpaceShipOne First Glide.... | [email protected] | Home Built | 1 | August 11th 03 04:03 AM |
