Dick Johnson methodology for measuring glider performance
Old July 12th 16, 09:56 AM posted to rec.aviation.soaring
Tango Whisky
Default Dick Johnson methodology for measuring glider performance
The air mass in an anticyclone generally sinks over its whole area. That's what generates the wind which turns clockwise around an anticyclone (northern hemisphere).
I agree that just for programming the polar into the flight computer, the actual precision does not matter much.
As to the Idaflieg measurements - there is no secrecy involved. Manufacturers put their gliders at disposition for those measurements, and no data will be published in the first two years. This stems from the times of Nimbus 3 vs ASW22 - with people looking only at best L/D, one of the two gliders being published with 2 points more would have made the other manufacturer go bankrupt.
The data is not published anywhere. If you're interested in a measurement of your type of glider, you send Idaflieg a request by email. If it exists, they will send you a paper copy, and a bill of about 10-15 Euros.
Dick Johnson Clint Soaring 4 June 6th 09 10:40 PM
Texas Glider Rally / Dick Johnson Wave Camp April 4 - 11 at Marfa Burt Compton - Marfa Soaring 2 March 27th 09 06:55 PM
Dick Johnson is gone. Burt Compton - Marfa Soaring 23 July 27th 08 05:38 PM
Dick Johnson's FTE of the Discus-2 Flavio Formosa Soaring 1 January 18th 07 03:18 PM
Contacts of Dick Johnson Francisco De Almeida Soaring 1 January 1st 06 06:07 PM
