Winching - Reverse Auto Tow
Old July 22nd 16, 01:38 AM posted to rec.aviation.soaring
Doug C
Default Winching - Reverse Auto Tow
On Sunday, November 2, 2003 at 1:49:20 PM UTC-5, wrote:
Can anyone direct me to Clubs / Web sites using this method of launching -
Interested in finding out more about this method, particularly from clubs
that operate from gravel/dirt strips
Thank you
John Spargo
Bruce: I can give you some quantitative numbers. In 1966-67 I made ~70 car-pulley tows in a 1:26 at Dansville using an asphalt runway that is almost 4000ft in length. The average tow was to 1300ft with some tows to 1500ft when the wind was optimum. For comparison, in 2009 I gave many instruction winch flights in either a Blanik L13 or a ASK21 using the same runway at Dansville. The average tow again was 1300ft and 1500ft when the wind was favourable. Thus under similar circumstances car pulley and winch give essentially the same height. Winch tows can utilize the full length of the airfield whereas car pulley tows are limited to the length of the paved surface because of the damage caused driving on the grass. Also winch tows are less intrusive than car pulley if the airport has mixed power and glider activity.
Doug C
Old July 26th 16, 02:12 AM posted to rec.aviation.soaring
Does anyone have particularly bad experiences with pulleys used like this. I am talking about the pulleys themselves. Has someone found a particular diameter that is too small. Obviously larger is better for both bearing speed and rope bending, but there are limitations on cost and availability....particular for the trial run I'm thinking about. I am considering a trial run with a swiveling pulley on the receiver hitch of a pickup, no guides, just the pulley, with around 8,000' of 1/4" poly hollow braid, flying a 1-26. That should prove the launch height, assuming the rope doesn't break on the first launch. I'm not sure what to expect at the pulley end, and don't want the rope jumping out of the sheave, catching and breaking. I doubt it will, but have no experience to back it up.
Old July 26th 16, 08:51 AM posted to rec.aviation.soaring
Peter Whitehead
On Tuesday, 26 July 2016 02:12:58 UTC+1, wrote:
Does anyone have particularly bad experiences with pulleys used like this.. I am talking about the pulleys themselves. Has someone found a particular diameter that is too small. Obviously larger is better for both bearing speed and rope bending, but there are limitations on cost and availability....particular for the trial run I'm thinking about. I am considering a trial run with a swiveling pulley on the receiver hitch of a pickup, no guides, just the pulley, with around 8,000' of 1/4" poly hollow braid, flying a 1-26. That should prove the launch height, assuming the rope doesn't break on the first launch. I'm not sure what to expect at the pulley end, and don't want the rope jumping out of the sheave, catching and breaking. I doubt it will, but have no experience to back it up.
Hi, I wrote an article "The Expedition Pilot's guide to launching" in the Dec2013/Jan 2014 edition of the UK Sailplane and Gliding magazine. It may be of interest. I use 12mm diameter high density polypropylene rope (Skyrope from Skylaunch) on snatch blocks with, initally steel pulleys on plain bearings 110mm dia. The bearings cooked in spite of lots of grease! These have been modified for regular use to nylon pulleys with steel ball bearings. The steel flaps or cheeks of the snatch blocks keep the rope where it should be. I use either a 2 to 1 or 3 to one system to keep the tow speed down ( we use some rough fields). If you are serious then I can send you a copy of the article and details of the kit, as well as the links to YouTube videos of some launches in the Lake District (UK) using 2 to 1 pulley system, with one pulley on a ground anchor and the other on the car's tow hitch (with the rope tail to another ground anchor). Everything used is inexpensive, and it works. Pete Whitehead
Old July 26th 16, 04:28 PM posted to rec.aviation.soaring
Does anyone have particularly bad experiences with pulleys used like this. I am talking about the pulleys themselves. Has someone found a particular diameter that is too small. Obviously larger is better for both bearing speed and rope bending, but there are limitations on cost and availability...particular for the trial run I'm thinking about. I am considering a trial run with a swiveling pulley on the receiver hitch of a pickup, no guides, just the pulley, with around 8,000' of 1/4" poly hollow braid, flying a 1-26. That should prove the launch height, assuming the rope doesn't break on the first launch. I'm not sure what to expect at the pulley end, and don't want the rope jumping out of the sheave, catching and breaking. I doubt it will, but have no experience to back it up.
Pete, I watched your videos, and those look like strong launches! Much better acceleration than we typically see. If you could send me an electronic copy of your article, I would love to read it.
Old July 26th 16, 04:44 PM posted to rec.aviation.soaring
Bruce Hoult
Hi, I wrote an article "The Expedition Pilot's guide to launching" in the Dec2013/Jan 2014 edition of the UK Sailplane and Gliding magazine. It may be of interest. I use 12mm diameter high density polypropylene rope (Skyrope from Skylaunch) on snatch blocks with, initally steel pulleys on plain bearings 110mm dia. The bearings cooked in spite of lots of grease! These have been modified for regular use to nylon pulleys with steel ball bearings.. The steel flaps or cheeks of the snatch blocks keep the rope where it should be. I use either a 2 to 1 or 3 to one system to keep the tow speed down ( we use some rough fields). If you are serious then I can send you a copy of the article and details of the kit, as well as the links to YouTube videos of some launches in the Lake District (UK) using 2 to 1 pulley system, with one pulley on a ground anchor and the other on the car's tow hitch (with the rope tail to another ground anchor). Everything used is inexpensive, and it works. Pete Whitehead
Yes, the launches shown here look like normal launches from a pretty powerful winch, not the average rather anaemic direct-pull car launch. Sadly, we don't see anything of the vehicle or launch setup
https://www.youtube.com/channel/UC_G...WaGdMMduefDVAg
Old December 29th 18, 04:19 AM posted to rec.aviation.soaring
John Foster
This one gives a little more detail of the mechanical set-up. Surprising they are able to get that kind of acceleration from such a small vehicle.
Old December 31st 18, 03:17 AM posted to rec.aviation.soaring
John Foster
https://www.youtube.com/watch?v=Q0rv1zOmyWg
Old December 31st 18, 04:18 AM posted to rec.aviation.soaring
Frank Whiteley
Anchored plus reverse pulley, so mechanical advantage of 2 plus speed reduction of 2, so the launch vehicle probably weighes 3,000lb or more so it can provide a 60mph rope speed at 30mph and not break traction on grass. Thus it can give a snappy launch. Slow turn around but better than just anchor pulley for short fields. Appears they can snap onto a working ridge nearby.
Frank Whiteley
Old December 31st 18, 05:26 AM posted to rec.aviation.soaring
Frank Whiteley
It's a anchor/reverse pulley, thus different from the old Cotswold setup. 2x pull advantage and 2x rope acceleration, so a 2600-3000lb launch vehicle could provide adequate power and not break traction on turf using 4WD.
IMVHO,
Frank Whiteley
Old July 26th 16, 05:39 PM posted to rec.aviation.soaring
Dan Marotta
On 7/26/2016 9:28 AM, wrote:
Snip If you could send me an electronic copy of your article, I would love to read it.
Or post it on Dropbox or similar so we can all read it!
Dan, 5J
vortex ring state at any point during an auto?? Greg Johnson Rotorcraft 18 August 30th 04 09:12 PM
Auto Fuel Residue Stu Gotts Restoration 4 May 12th 04 08:52 PM
Auto conversions & gear boxes Dave Covert Home Built 56 April 1st 04 06:19 PM
Arrow auto gear extension oddness Roy Smith Owning 10 March 8th 04 02:27 AM
VOR & Reverse Sensing mrwallace Piloting 1 August 21st 03 03:08 AM
